Old 10-29-2020, 10:31 AM   #21
Conaway2
Conaway2's Avatar
Default Re: Source for epoxy-filled 6 volt coil ?
The Pertronix epoxy-filled coil arrived yesterday and is now installed, and the car runs great.
The coil I swapped out was a Ford-script reproduction - looked almost exactly like an original SP coil except the screw terminals are straight not slanted. It is an oil filled coil.....so why would it be sold without a warning to not install upside down ??
I plan to carry the original tar-filled SP coil I have as a spare - not the modern repro.
Conaway2 is offline   Reply With Quote
Old 10-30-2020, 02:11 PM   #22
DBSHELTON
I just bought a Pertronix Epoxy coil from Amazon.
DBSHELTON is offline   Reply With Quote
Old 10-30-2020, 03:21 PM   #23
Jim M
Jim M's Avatar
Purdy,
I want to order one for my 29 Roadster - 6V. Just looked at the site and it didn't look like there was a diffent one for 6V vs 12V? Am I missing something or will it work on 6 or 12 volt?? Thanks, Jim
Jim M is offline   Reply With Quote
Old 10-30-2020, 08:22 PM   #24
31Abone
31Abone's Avatar
Do not buy one from the big supply house's they are junk..been thru that ..get a old 50's coil and clean it up ..sc
31Abone is offline   Reply With Quote
Old 10-30-2020, 09:21 PM   #25
Conaway2
Conaway2's Avatar
I just bought the 6V coil mentioned in post #4. So far, it’s working quite welll.
Old 10-31-2020, 07:36 AM   #26
Patrick L.
Patrick L.'s Avatar
Originally Posted by Jim M View Post
Purdy,
You can get it right from Petronix. 1.5 ohm. Make sure to get epoxy filled.
Old 10-31-2020, 04:47 PM   #27
Purdy Swoft
Purdy Swoft's Avatar
Purdy,
Jim , I use the twelve volt version . I got mine from Amazon but they can be purchased from Auto Zone , Advance Auto , Pertronix or most parts houses The six volt version will probably need to be ordered .. You can google Pertronix for more information .
Old 10-31-2020, 05:57 PM   #28
1955cj5
1955cj5's Avatar
I ordered mine through Summit....They have a warehouse in Reno so things get here in just a couple of days..
https://www.summitracing.com/parts/pnx-40111
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
