Old 10-23-2020, 06:26 PM   #1
Yoyodyne
Yoyodyne's Avatar
Default L-100 cam in a 221
I've been forced to rethink the motor I've been building and will start over with a 36LB block with maybe .030 overbore and stock stroke. I'll be using stock 36 aluminum heads. I plan to optimize the CR with .040 piston to head clearance and milling the heads. I have a Fenton 2 carb manifold and 2 Holley 94s. I also have an L-100 cam.
I've had other engines with a lot of cam and not a lot of compression, revving something to make it work is not a new experience, I don't need a torque monster to have fun. This is going into a 36 pickup with 3.78 gears and a stock 39 trans, just for occasional local fun.
Will this cam work OK in a 221?
Would porting the block be important in this combination?
Yoyodyne is offline   Reply With Quote
Old 10-23-2020, 06:33 PM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: L-100 cam in a 221
I've probably built more engines than anyone else with the L-100, it was the goto cam. However they didn't run well in a small engine especially in a heavy vehicle . But they do sound good. Why not the 1007b, sounds good and would probably run better.
Old 10-23-2020, 06:47 PM   #3
Brian
Brian's Avatar
Yoyo, I've built and run numerous 221's, including the L100 and Fenton twin as you're proposing. I agree with Ron; the L100 is not a good cam in this application. Try an Isky 88 cam along with your other mods, take the lip off the flywheel, use a 9" clutch, and yes, port the block. The idea is to lighten everything as much as possible and allow the thing to breathe. Enjoy...
Old 10-23-2020, 07:20 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
This would be my choice in cams . . . but there are plenty of ways to "skin this cat".
Old 10-23-2020, 07:55 PM   #5
Yoyodyne
Yoyodyne's Avatar
Thanks for the knowledgeable recommendations! A quick search shows isky cams only for 42-up, would I have to give up the 3 bolt distributor and front plate?
Old 10-23-2020, 08:12 PM   #6
Brian
Brian's Avatar
Just use your stock cam and get it ground by one of 'our' camgrinders on here....
Old 10-23-2020, 09:48 PM   #7
Ol' Ron
Ol' Ron's Avatar
The L 100 need compression and cubs to build the torque lost to a long cam. Thus you have a streetable cay. The 276 does this.
Old 10-24-2020, 07:29 AM   #8
Bored&Stroked
I've had Pete grind some 1007B profiles (and a lot of others) - he does extremely nice work. Also Kiwi Tony grinds a lot of cams and is highly respected on the Ford Barn world (though I don't know what masters he has).
Truth be told, I'd rather have a stock cam reground these days than buy a "new" one. But hey, that is just me . . .
Old 10-24-2020, 04:29 PM   #9
Pete
Pete's Avatar
Just for the book, I won't put a race grind on an after market cast core.
The heat treat is really bad. (inconsistent)
Old 10-24-2020, 04:48 PM   #10
Tim Ayers
Meaning, using a stock Ford camshaft for regrinds, right?
Old 10-24-2020, 05:19 PM   #11
Brian
Brian's Avatar
I always use a steel camshaft out of an early engine...
Old 10-24-2020, 05:47 PM   #12
Pete
Pete's Avatar
Yup.
Old 10-24-2020, 07:10 PM   #13
Yoyodyne
Yoyodyne's Avatar
Since Pete is here, what is the acceptable smallest diameter for cam journals to reuse? I checked the 3 I have, they range between 1.7955/1.797.
What do (or should) installed cam bearings measure?
Old 10-24-2020, 07:40 PM   #14
Brian
Brian's Avatar
Cam journals measure between 1.796-1.797". Wear limit is 1.795" Clearance in brgs is .002"
this is what i do; Install .010" undersize cam bearings. Measure the installed dia of each bearing. As a reground cam is ground between centres, I put the camshaft between the same centres and grind the journals to suit the installed bearings. Do not assume that .010" bearings, when installed will measure exactly .010 u/s! Doing it this way ensures perfect concentricity of the camshaft journals and lobes, also, I am assured the correct clearances are in place, with no resultant loss of oil pressure through sloppy clearances.
Old 10-24-2020, 08:18 PM   #15
Ol' Ron
Ol' Ron's Avatar
Where do you get under size cam bearings.??
Gramps
Old 10-24-2020, 08:39 PM   #16
Brian
Brian's Avatar
They are out there....
Old 10-24-2020, 08:48 PM   #17
Pete
Pete's Avatar
For clearance, I run .002 on street engines and .003 on race engines.
I use 1.795 as a minimum as long as it is round.
Old 10-24-2020, 08:53 PM   #18
Pete
Pete's Avatar
Gramps
H&H may have them.
Old 10-25-2020, 12:17 AM   #19
Yoyodyne
Yoyodyne's Avatar
Gramps
Most of the new parts sellers have them, they are currently made. I have a set I don't need now.
I had Dave Generous grind my L-100. The only usable core I had at the time was worn undersize and needed the journals ground. Dave said he couldn't do it on his grinder, he wanted me to send it elsewhere first to have that done before he ground the lobes. That's when I bought this set of .010 bearings. I found a the cores I have in parts engines since then while looking for a good block.
