07-28-2021, 11:12 AM | #1 |
Radius rod ball
I just discovered that my RR ball is not 1.5" in diam, but 1.45" top to bottom and 1.48" side to side. Most surprising (to me) is that I can feel a ridge around the 'belt' of the ball--look at a picture of a sleigh bell. This ridge is most noticeable at the front, almost non-existent at the back. Upon removal there were no springs and spacers on the ball socket, but there was a rubber ball. The notch in the bottom half of the ball socket was shiny, indicating some contact wear from the 'neck' of the steel ball. After reading many posts about this assembly (rubber ball vs not), I am inclined to buy a steel ball washer and original style ball cap kit. From my description, is this a reasonable move ?
07-28-2021, 11:16 AM | #2 |
Re: Radius rod ball
I like to fix them once so I would weld it up and file it down. But the washers and the rubber work as a temporary bandaid fix.
"The more things change, the more they stay the same." |
07-28-2021, 11:45 AM | #3 | |
Re: Radius rod ball
I am more inclined to believe that 0.050" (-25 thousandths per side) is not a huge issue. Can it be better, ...yes. The biggest issue with using the washer is your present ball is not perfectly round, and so when there is twist of the radius rod (wishbone) with a washer, it can actually cause binding that I have seen break the cast clutch housing. Since you have it that far apart, add a few weld passes for filler and use a flat bastard file to re-shape. The best way to check these is to machine a piece of tubing to 1.500" ID, and use it as a gage to check for high spots on the welded areas. If it binds in an area, file it more until it just slips over the ball in different directions. |
07-28-2021, 02:01 PM | #4 |
Re: Radius rod ball
My welding and machining skills are such that I would need to do this on a bench, not on the car. Les' instructions entail complete disassembly of the front suspension and brakes. Could I just relieve the weight from the front spring, remove the brake actuating arms, and drive (gently) the spring perches up thru the axle?
07-28-2021, 02:04 PM | #5 |
Re: Radius rod ball
Perches are difficult to remove.
They rust in place. |
07-28-2021, 03:37 PM | #6 | |
Re: Radius rod ball
07-28-2021, 05:19 PM | #7 |
Re: Radius rod ball
I just tightened the bolts on the U-joint housing after installing the engine back into the straightened frame. Radius rod is a project for another day
