06-09-2021, 05:53 AM | #1 |
Jacking Instructions
I’m new here and this is my first post. I recently purchased a ‘28 Sport Coupe. I’ve been on the fence about keeping it as it needs quite a bit of engine work. That being said, what is the proper and safe way to jack up one of these and support it? I somehow get the idea that it’s done differently. I would need to remove the oil pan and probably piston #1. Thanks
06-09-2021, 06:37 AM | #2 |
Re: Jacking Instructions
I have a heavy duty floor jack and four jack stands. I jack in the center of the front axle and on the differential housing, although several people will tell you not to do that for fear of bending the rear axle. I put the jack stands just inside of where the wishbones attach to the front axle to assure that they do not slip outward and put then at an angle. The rears I put near the wheels with enough room to do any work on the brakes.
I have a couple of the small ramps that I can drive the car up on, one under each wheel, in the front or in the back depending on where I want to crawl under. I will sometimes jack up the car with the floor jack and put the ramps under the wheels and then, when done, just drive off. Do not use concrete blocks as then can break. As in all work under any car, safety is the primary concern. I shake the car when it is up to make sure that it is secure. A lift is a great addition to any garage although I don't have the overhead room for one and there is no place outside that is level enough.
06-09-2021, 07:13 AM | #3 |
Thanks. Jack stands under the front axle, then?
06-09-2021, 06:43 AM | #4 |
Welcome to the Barn. Hopefully there is a club in your area that will offer you assistance. Be patient. In the end it will all be worth it. Good luck ! Wayne
06-09-2021, 07:13 AM | #5 |
06-09-2021, 07:20 AM | #6 |
and answers to questions you might have here on the Barn.
IN GOD WE TRUST - SEMPER FIDELIS John |
06-09-2021, 07:27 AM | #7 |
The thing you don’t want to do is put a jack under the radius arms. They are not strong.
06-09-2021, 08:26 AM | #8 |
To be clear, on the front axle.
06-09-2021, 08:33 AM | #9 |
I usually jack under the front axle at the perch. Jack stands one at a time
06-09-2021, 08:46 AM | #10 |
And buy the best Jack stands you can find. The most expensive (read quality) are far cheaper than an ER visit or your funeral. When I have my car on the stands I leave the floor jack under whichever end I'm working on just as an added safety measure.
06-09-2021, 11:05 AM | #11 | |
And on the subject of jack stands - I see that there are now some aluminum jack stands on the market. The engineer in me says that there is no reason that an aluminum product, properly analyzed, cannot be engineered to an application to be just as strong as steel, but the old fart in me also says (and louder) that steel is real. I have a couple of steel jack stands that have followed me from place to place since the 60's or 70's that are heavy, yes, but that I have absolute confidence in. Newer stuff just seems flimsy by comparison. Minimum capacity on the new jack stands seems to be 2T. A Model A itself is a hair over a ton (say 2600 lbs, varies by body type) so you're not coming close to capacity at 650 lbs/corner. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
06-09-2021, 11:19 AM | #12 |
Like JayJay said.
I cringe at the cheap stuff Harbor Freight sells Why cut corners pay for GOOD quality equipment. Don't go on the cheap. You will be asking yourself that very question just as you slip into unconsciousness from the anesthetic they are giving you as they are about to amputate that leg that was mashed and mangled from a car falling on it. But I saved a few bucks |
06-09-2021, 10:23 AM | #13 | |
06-09-2021, 10:50 AM | #14 |
06-09-2021, 12:29 PM | #15 |
06-09-2021, 12:59 PM | #16 | |
You might see if you can find a scrap of carpet or a large piece of cardboard to lay on, makes it a lot more comfortable. JayJay
06-09-2021, 03:17 PM | #17 |
No need to jack for an oil change. You want the pan level anyway. Get large sheets of cardboard from big box stores like Wal-Mart and Sam's Club. It's free!
06-09-2021, 10:15 PM | #18 |
If jacking the differential by placing the jack under the banjo every model A would have a bent axle.
06-10-2021, 05:13 AM | #19 |
Re: Jacking Instructions- Defective Harbor Freight jack stands
Note that some Harbor Freight JACK stands were recalled
THEN THE "Replacement STANDS" were recalled as defective. Guess that SOME of HF ENGINEERS DID NOT PASS engineering 101! first batch recalled in May 2020. https://www.caranddriver.com/news/a3...llapse-recall/ Then in July 2020 the REPLACEMENT batch was recalled! https://www.caranddriver.com/news/a3...h-jack-stands/ Last edited by Benson; 06-11-2021 at 08:41 AM. |
06-11-2021, 08:15 AM | #20 |
I have some 12x15 x20” hardwood blocks and always place under things jacked for “insurance “
