Old 08-22-2012, 08:08 AM   #1
Smitty
Smitty's Avatar
Default Headlight Switch Position
Should high beam be on the first click of the switch or all the way to the right?
High beam filament should be facing the top of the reflector correct?
Thanks, Steve
Smitty is offline   Reply With Quote
Old 08-22-2012, 08:27 AM   #2
TomW
TomW's Avatar
Default Re: Headlight Switch Position
Low beams are the first click to the right. High beams are all the way to the right. The high beam filament is at the center of the bulb, with the low beam filament above it .
TomW is offline   Reply With Quote
Old 08-22-2012, 10:11 AM   #3
springerpete
springerpete's Avatar
I guess I am confused. With my 29 when I turn the switch lever to the left the low beams come on. Centered = no lights and one click to the right = high beams. Is this correct or should all the "clicks" be to the right ?
springerpete is offline   Reply With Quote
Old 08-22-2012, 11:19 AM   #4
CarlG
CarlG's Avatar
Clock positions:
7 = Parking/cowl lights
6 = OFF
5 = Low Beam
4 = High Beam
Old 08-22-2012, 11:43 AM   #5
Franchise_24
Franchise_24's Avatar
Don't feel bad, my whole setup is jacked up. I've got one of those repo switches and it is absolutely horrible. We played with it for 2 days, and the only way we could get it to work is like this (pay attention it's wierd)
3 = Off
4= Parking Lights
5 = Low Beams
6 = High Beams
Strange huh?
Any other way we tried to get it to work with the normal 6'oclock as off it didn't work properly. Oh well.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 08-22-2012, 01:07 PM   #6
Pat Martone
Pat Martone's Avatar
My OFF position is at 7PM instead of 6PM, and I don't know if I can fix that?
(My cowl lights are at 8PM and low and high beams are at about 5PM and 4PM repectively, which I think is the correct sequence if not the right place on the clock.)
Pat Martone is offline   Reply With Quote
Old 08-22-2012, 05:02 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Do you have the early fluted lens headlamps with only park/headlight?
Of course most bulbs have been changed to low/high and no parking filament. So, if this is what you have then it sounds OK.
7 is park (or low beam, if bulb is switched from original)
6 is off
5 is high, or just headlight if original.
Old 08-23-2012, 02:45 PM   #8
AL in NY
AL in NY's Avatar
When you look at the Model A wiring diagram, and compare it to the switch, should you be viewing the switch (or wire placements) from the drivers seat or from the bottom of the steering column so that your view matches the diagram?
AL in NY
AL in NY is offline   Reply With Quote
Old 08-23-2012, 04:35 PM   #9
springerpete
I get most all of my parts from TAM'S in Massachusetts. Joe has told me several times that if I can find an "original" can, the unit that holds the wires, etc at the bottom of the steering column, to get it. Reading thru this forum and talking to others at meets, I hear the same. Is there anyone who makes a good, solid repro unit ? It seems there is so much trouble with the current stuff that it would be a good candidate. Sadly, I am not the one to manufacture it.
