Old 03-24-2013, 09:50 AM   #1
Rock Hornbuckle
Rock Hornbuckle's Avatar
Default T-10 4-speed on a Flathead
Any previous threads on marrying a t-10 to a flathead. I have a t-10 and a t-5. I'm thinking of putting one of them in my '41. I have an 8BA in the car with a '39 3-speed and a Columbia 2-speed. I was thinking of replacing the Columbia with a standard 3rd member. Any suggestions?
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 03-24-2013, 10:04 AM   #2
DICK SPADARO
Default Re: T-10 4-speed on a Flathead
Neither your t-10 or t-5 is a simple conversion. If your goal is to improve your hi speed and lower the engine RPM both the 3 spd and the T10 both have 1-1 final drive. Other than another intermediate gear its the same. Since the T-5 is an over drive this gives you approximately a 30% over dive ratio so in 5th overdrive you would have a similar ratio with a stock 3:78 rear end as you would with the Columbia engaged and the 3 spd.
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 03-24-2013, 10:27 AM   #3
Ol' Ron
Ol' Ron's Avatar
The biggest advantage of the T-10 is: most bolt to the stock ford 59/53 passenger car bell housing. They also have a dual bolt pattern on some models. for other applications.
But as Dick says you will not improve mileage or cruise RPM, so after spending a great deal of money and time. You'll still have the same thing.
Old 03-24-2013, 05:40 PM   #4
rotorwrench
rotorwrench's Avatar
The late 51 Mercury bell housing will work for a narrow 4-bolt Borg Warner bolt patern and will also work with the 1941 clutch equalizer shaft as long as the engine is positioned for it.
The other option is the truck 4-speed hogs head bell with an adapter.
Old 03-24-2013, 06:17 PM   #5
Bassman/NZ
Bassman/NZ's Avatar
Except you'll have synchros on all, nda a trans that a flattie will not destroy.
Bassman/NZ is offline   Reply With Quote
Old 03-24-2013, 08:09 PM   #6
paul2748
paul2748's Avatar
Go with the T-5 - for the o/d. But after all is said and done, will you be better off with that and conventional rear vs the Columbia and stock trans??
Old 03-25-2013, 04:25 AM   #7
Mart
Mart's Avatar
Sort of following the same idea, as you already have the columbia, you already have a near perfect setup. It simply isn't worth fitting the other boxes. If you fitted the 4 speed and regular rear you'd have a definite de-grade of the current setup. Don't forget fitting either of the gearboxes mentioned will involve chassis mods and converting to an open drive rear end, with suspension mods.
I can't see enough benefit to warrant the work involved.
You might even devalue the car quite substantially.
Mart.
Old 03-25-2013, 06:47 AM   #8
4tl8ford
4tl8ford's Avatar
You may run into problems with the shift location with both the T-10/T-5 - They both come thru the floor to the rear of the 39 top shifter - In the 48 & up trucks there is interference with the seat.
Dick C
Erie, PA
1996 Exploder
1952 Ford F2 (Driver)
1948 Ford F1 Panel (Frame off resto-rod)
1946 Ford Coupe (Basket case)
4tl8ford is offline   Reply With Quote
