Old 02-02-2013, 02:56 AM   #1
1962300
Default '32 Ford Throttle to Dual 97's
I am working on connecting my stock '32 Ford Gas Spoon Linkage from the Firewall to my pair of Stromberg 97's on the Passenger side. Anyone have a good picture of the type of rod they used and if they connected the rod to the front or the rear carb? I have the carb's connected over on the drivers side.
1962300 is offline   Reply With Quote
Old 02-02-2013, 07:40 AM   #2
Wingfield
Wingfield's Avatar
Default Re: '32 Ford Throttle to Dual 97's
Try this link
http://www.stromberg-97.com/linkage/...ts.asp#prodfrm
Wingfield is offline   Reply With Quote
Old 02-02-2013, 09:17 AM   #3
Uncle Bob
Uncle Bob's Avatar
Here's one example from my '30 roadster:
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 02-02-2013, 10:01 AM   #4
cuzncletus
cuzncletus's Avatar
Speedway sells linkages with snap on ends for both the carbs and the pedal. My recommendation is to order a "too long" rod. Though the rod has both right and left hand thread, the rod threads easily and can be cut to any length and then run over with a die. Too long permits a bend in the rod. Without the bend, the pedal arm may just bring the throttles down to a certain point. The bend allows the throttle to come fully to wide open position. It takes some tinkering but is simple and looks neat.
cuzncletus is offline   Reply With Quote
Old 02-02-2013, 10:24 AM   #5
ct1932ford
ct1932ford's Avatar
Here's mine!
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
