10-02-2020, 06:44 AM | #1 |
Ford Blue Hub cap paint?
Anyone paint their own hub caps? Suggestions on a good match of the "Ford" blue paint OR have a mix formula that you use? I "quick" checked a few like Third Gen, Mac's, Carpenters, Snyder's and a forum check here but did not find any thing. I will call Mike at 10am but in the mean time figured I would toss a line out here on the barn. ALSO any pointers on best found techniques...I have to paint to "Locking" caps!!! Thanks "Barner's" and Happy Friday to all.
10-02-2020, 07:26 AM | #2 |
Re: Ford Blue Hub cap paint?
or Reflex Blue (155L). One shot is used by sign painters and widely available.
My hub caps are Process Blue. |
10-02-2020, 07:46 AM | #3 |
10-02-2020, 09:46 AM | #4 |
Robert,
The original name of the color was "Harding Blue", but one of the One-Shot sign painter blues is a very good match. I should know which one off the top of my head, but not today. My recollection is leaning toward the Reflex Blue. |
10-02-2020, 10:20 AM | #5 |
I know color and hue is hard to judge from a picture PLUS ad in the lenses ability of light transmission BUT based on Jersey Devil's post above, the "Process Blue" looks too blue OR by my eye needs to be a shade or two darker.......SO I think your memory is correct David in that the Reflex Blue is the ticket!!!
10-02-2020, 10:37 AM | #6 |
Check the dollar tree for nail enamel. Built in brush.
Works good Lasts long time |
10-02-2020, 11:28 AM | #7 |
Just painted in Ford on my '41 coupe hubcaps. Takes a steady hand. Lighting the work area is tricky because of reflections; had to turn off the overhead lights and illuminate the hubcap from the side, to shadow the edges of the indented letters. Used a sharpened popsicle stick dipped in a little cup of xylol to scrape and wipe off the inevitable bits of paint that went outside of the lines. Looks pretty good from a few feet away.
10-02-2020, 02:27 PM | #8 |
Pin stripping tape is a good edge maker when doing detail work such as this.
It gives you that "cushion" of error and when the paint is dry, you remove it and have a straight clean edge. |
10-02-2020, 02:54 PM | #9 |
Yes, I got a roll of 1/8th which I think will work swimmingly on the majority of the cap, the "centers" of the "8" will be "TIGHT" so we'll see how that goes!!!! ALSO Sign Painters also sells a "Flow Enhancer" so that will be in order too!!!
10-02-2020, 03:44 PM | #10 |
10-02-2020, 04:03 PM | #11 |
This is the stuff I use. The paint dries a bit slower but flows out well, eliminating any brush marks. It is Reflex Blue...
10-02-2020, 05:26 PM | #12 |
I Found that Testors Enamel # 1111 Dark Blue was a very good match, Shops that sell Models sell the paint, here in Canada , Toys R Us has the Testors Paint.
10-02-2020, 06:04 PM | #13 |
Mario 39
Go into the One Shot Paint web site and there is a location finder by zip code. Usually art supply and hobby shops sell the paint. Pinstripes also use One Shot paint. If you go on there Website they have a color chart. Hope this helps, Tom |
10-03-2020, 08:36 AM | #14 |
If your just purchasing new hubcaps I think Drake has them already painted.Decals hold up pretty good for a quick fix!
https://www.ebay.com/itm/Ford-hubcap...-/282568872262 |
10-03-2020, 12:46 PM | #15 |
Amazon/Amazon Prime
