Old 06-16-2020, 06:00 AM   #1
shew01
shew01's Avatar
Default Can anyone recommend a good 6V timing light?
The previous owner installed a Nu-Rex timing indicator on the front of the engine, and he left me the vendor instructions. However, I don't have a 6 volt timing light.
Can anyone recommend a good 6 volt timing light?
Old 06-16-2020, 06:32 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Can anyone recommend a good 6V timing light?
Use a buzz box, a test light, or a continuity tester instead. Align the mark on the pulley to whatever the desired degree number on the indicator, and then the points should just break or open at that location.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-16-2020, 07:02 AM   #3
Jim Baskin III Pa.
Jim Baskin III Pa.'s Avatar
I have Pertronix 6v Ignition in my distributor and Nurex timing indicator and have used a 12v timing light for the past 12 yrs.I just have to reverse the leads for power.
Jim Baskin III Pa. is offline   Reply With Quote
Old 06-16-2020, 07:14 AM   #4
DBSHELTON
I use a battery operated timing light.
DBSHELTON is offline   Reply With Quote
Old 06-16-2020, 07:23 AM   #5
Jim/GA
Jim/GA's Avatar
My timing light connects to the battery for power. I originally got it for my 12 volt cars (back when you could actually set the timing on a car -- ha ha ha). It works just fine on my 6 volt Model A.
Just pay attention to the color of the battery leads. The red one goes to ground, if the car is wired to original positive ground. Then the black one goes to a power source; I use one of the brass wing nuts on the cover of the terminal box.
My timing light uses inductive pickup (a small black end clamps around the ignition lead for plug #1). This is trickier to do with the original style bronze strips connecting from distributor body to spark plug. I slip a short piece of clear tubing over the bronze strip first, to insulate it from the induction pickup, then clamp over that. It works.
Jim Cannon
"Have a Model A day!"
Old 06-16-2020, 07:39 AM   #6
Bob from Northport
Bob from Northport's Avatar
Check Ebay for 6v Snap On timing light
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 06-16-2020, 08:01 AM   #7
ryanheacox
ryanheacox's Avatar
The timing pin works great on 6, 8 or 12V
Old 06-16-2020, 08:18 AM   #8
Ruth
I would never buy a Snap-On timing light (or anything else electrical). I had one and it spent more time being repaired than in use. Great hand tools but their electronics SUCK.
Ruth
Old 06-16-2020, 08:23 AM   #9
Y-Blockhead
Y-Blockhead's Avatar
Oh, Boy ain't that the truth. I connected my advancing timing light to the bronze strip and when I pulled the trigger I got the shock of my life. I have a 12v Pertronix Flamethrower coil so that made it even more lively.
Not a good thing when you have a Pacemaker...
Old 06-16-2020, 09:30 AM   #10
tnhammond
tnhammond's Avatar
This battery powered timing light works quite well. Just slip an insulating sleeve over the number 1 bronze strap.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
tnhammond is offline   Reply With Quote
Old 06-16-2020, 09:47 AM   #11
Bruce_MO
I have powered my 12V timing light with my 6V/12V battery charger... just select 12V and power it up.
Bruce_MO is offline   Reply With Quote
