Old 10-29-2014, 10:14 PM   #21
Cartravel
Default Re: Question on engine parts interchangeability
The cam bearings I ordered were standard size (both times). The rings I ordered were for 0.030 over 3 3/16. Filing rings to fit is not uncommon in an engine assembly, but I've never been told not to do it.
Cartravel is offline   Reply With Quote
Old 10-30-2014, 02:46 PM   #22
Cartravel
Originally Posted by Walt Dupont--Me. View Post
I feel bad about all the wrong stuff you got for engine. Walt
No reason you should feel bad. I've messed with old cars enough to expect a learning curve. I just appreciate having this group to ask questions of.
After looking further I believe the oil rings were 3/16 in the 8BA, but 5/32 in the 59AB. The rings I bought clearly state for 39-48 in the catalog, but apparently I got later ones anyway. It looks like the parts supplier sabotaged me with both the rings and cam bearings.
Could my piston grooves be machined to 3/16" width? I still don't know why moly rings cannot be filed to correct the end gap.
I don't believe I have the "green bible". I have 39-48 Service Manual and probably a dozen other books and manuals. I haven't run across the difference in rings. I guess this is one way to learn.
