06-16-2020, 04:32 AM | #1 |
32 transmission/clutch
recently bought a V8 32 roadster. When starting in neutral you can't get the trans to shift, all gears grind. Shut the car off and put it in gear no problem, then start and let the clutch out and it seems normal. Clutch grabs right at the bottom. Is this just out of adjustment? Have taken it down the driveway and shifted from 1st to 2nd okay. I have had stuck clutches before, but this is different.
06-16-2020, 04:58 AM | #2 |
Re: 32 transmission/clutch
Just assuming you checked adjustment...the issue is that clutch doesn´t disengage enough.
If they changed it over to hydraulic and kept the long clutchlever on the gearbox you will get less travel on the pressureplate to disengage. And i´ve had frictionplates that has been redone riveted in the wrong way so they expand giving this symptom. |
06-16-2020, 06:52 AM | #3 |
The original specification was that there should be an inch and a quarter of free travel of the pedal before the clutch starts to engage and that the pedal should be adjusted if the free travel is less than one inch. (Page 52 of the August, 1932 Service Bulletins)
06-16-2020, 07:08 AM | #4 |
You should be able to feel the "free travel" at the top (with the floorboards and the metal plate around the pedals/column in) - of about an inch or so. Then you should feel the throw-out bearing engaging the clutch forks. |
