Old 05-11-2021, 02:49 PM   #21
psimet
psimet's Avatar
Default Re: dropping the pan
Picked up a deep well 1/2" socket - 1/4" drive, wobble/universal, and a 6" extension from Home Depot the other day and was able to get on top of every bolt on the pan after removing the inspection plate. It fit fine.
psimet is offline   Reply With Quote
Old 05-12-2021, 04:18 PM   #22
Dave in MN
Dave in MN's Avatar
I use a 1/4" cordless impact driver with a 1/2" nut driver with 6" shank.
I use it for off and on...
Good Day!
Dave in MN is offline   Reply With Quote
Old 05-12-2021, 04:18 PM   #23
Dave in MN
Dave in MN's Avatar
Double post...Second one removed ...Tried to .....
Old 06-22-2021, 11:57 AM   #24
rfequity
What kind of gasket do most use when they reinstall the pan? Also, is there something to do to some "rear seal" when you are doing this job?
rfequity is offline   Reply With Quote
Old 06-22-2021, 12:38 PM   #25
1929
I also had to grind the socket to get a good fit, it is now my oil pan only socket.
1929 is offline   Reply With Quote
