Old 01-10-2015, 05:48 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default fuel pump 59ab
Where do you guys recommend getting a new fuel pump for a 59ab? Someone awhile ago said Napa, my favorite Napa counter man could not find one, he could get one for the 8ba, Thanks Guys, Walt
Old 01-10-2015, 06:03 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: fuel pump 59ab
Let Charlie ny build ya a good one. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-10-2015, 06:19 PM   #3
40ford
40ford's Avatar
I used a Airtex Mechanical Fuel Pump from Advance Auto Parts.Part # 571 ($60).Probably one of the best out there now.
40ford is offline   Reply With Quote
Old 01-10-2015, 06:20 PM   #4
flatjack9
flatjack9's Avatar
I'll second that. Charlie , that is.
Old 01-10-2015, 06:46 PM   #5
qmdv
qmdv's Avatar
http://www.amazon.com/Airtex-571-Mec.../dp/B0027ICTFW
A bit cheaper
Tim
qmdv is offline   Reply With Quote
Old 01-10-2015, 07:14 PM   #6
37 Cab
37 Cab's Avatar
Will this pump fit my 37? Looks like the same one but I am still pretty flathead ignorant..
Tommy
37 Cab is offline   Reply With Quote
Old 01-10-2015, 09:18 PM   #7
Fibber Mcgee
Fibber Mcgee's Avatar
Napa has it online. The part number is AFP571. Priced at $48.16.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 01-10-2015, 09:31 PM   #8
Walt Dupont--Me.
Thanks Fibber, I'll check with my Napa place Monday, we'll see if he's smart enough to look that up on his puter Walt
Old 01-10-2015, 09:38 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
I would be concerned about the pressure produced by those fuel pumps sold by NAPA, Airtex and others.
A pump rebuilt by Charlie ny or Ken ct would have a diaphragm resistant to todays alcohol enriched gas and the correct pumping pressure.
John
Old 01-10-2015, 11:08 PM   #10
Graeme / New Zealand
Graeme / New Zealand's Avatar
Sumitt Racing.
Good prices good service.
I've just ordered a Carter M825 for a 59A. (the M826 is for an 8BA). US made by Federal Mogul .
http://www.summitracing.com/int/sear...rder=Ascending
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 01-11-2015, 01:36 AM   #11
ford38v8
ford38v8's Avatar
Tommy, yes it will fit, and will provide a built in glass sediment bowl, very useful to settle out the impurities caused by the fuel we get today.
JM 35 Sedan made a valid point regarding the spring pressure. Should you discover an excess fuel pressure situation as a result of installing this new pump, You may certainly replace it with the spring from an older pump, as they are all interchangeable.
You haven't been posting questions here as I'd have expected you to do since we conversed last. We're here to answer, but the questions are a prerequisite!
Alan
Old 01-11-2015, 10:15 AM   #12
G.M.
A slightly higher COLD fuel pressure is better than a lower pressure with todays gas. I like it in the 4.0 to 4.5 range cold and as the pump heats the pressure drops to say 3.5. This gas boils in the 125 degree F range and the hotter it gets the lower the pressure gets and you get vapor lock. When real hot you will see the pressure get down in the 2 lb range and start jumping up and down in pressure. With a slightly higher pressure it will usually pump through the problem before it starts. Cooler areas in the country may never or vary rarely have this problem. I live where it's over 80 degrees most of the year with times of well over 90 for long periods. I have done MANY tests under the same conditions under this heat condition and the results are predictable. I might add I use the double ball check valves available from Uncle Max to control carb float level. This type valve is very pressure sensitive and constantly opens and closes very slightly maintaining a fuel level the eye can not see change. Any one making or rebuilding pumps is or should be using material compatible with todays fuels and most additives. G.M.
www.fordcollector.com
Old 01-11-2015, 10:37 AM   #13
Kube
Kube's Avatar
If you go to a rebuilder, I'd suggest Charlie as your best option. He actually tests the pumps. What a concept, huh?
Old 01-11-2015, 11:49 AM   #14
Boss1940
I also would recommend Charlie from NY , I agree with JM 35 , his diaphragms are superior for today's fuels. And like KUBES said they are tested.
Boss1940 is offline   Reply With Quote
