06-02-2011, 04:10 AM | #1 |
Flange Axle conversions
Hey, who has used or is using 9 inch axle conversions or any flanged axle conversions in Ford V8 banjo axles????
Any help appreciated.
Life is not a dress rehearsal... |
06-02-2011, 04:20 AM | #2 |
Re: Flange Axle conversions
06-02-2011, 05:03 AM | #3 |
had Hot Rod Works redo mine in my 40 and best thing I did for that rear except put a Mitchell OD in
06-02-2011, 10:21 AM | #4 |
Several of the older hot/street rod magazines had articles on this conversion. IIRC, the first one that I had seen used 50 Merc axles. I think that there was another using the early 1950's Ford truck axles.
06-02-2011, 02:50 PM | #5 |
Yeah I got a quote from them but at $3795 USD for a complete axle I am looking around at all options. The parts kit alone is $1295.00 but requires machining and a core on top of that. Dont doubt they are an excellent product looking at the quality.
06-02-2011, 03:53 PM | #6 |
I did this on my 32 using a 36 Ford axle. Here's how it went: I bought the axle housing ends from a Ford 9", along with the backing plates, brake asemblies and drums (50 bucks). Mine have the 5 X 5 1/2" old Ford bolt pattern. I did not get the axles, as I had no idea what i was doing yet. I then had my machine shop take and cut the 36 Ford axle bells, then add the new 9" ends. They used a tube affair to make sure everything lined up properly (80 bucks).(Remember that on a 36 axle there are NO spring hangers, so I didn't have to worry about those). Also, on a 36 and earlier Ford axle, the spider gears are a 12 tooth design, and must be replaced with the later 11 tooth type to be able to use the new/different axle SIDE gears. I bought the side new gears from Hot Rod Works (225 bucks). I had to find the replacement spider gears on the net (No big deal and cost about 20 bucks). After I got everything setup, I measured for axles and bought them from HRW (400 bucks). I then had the brake drums turned, got new wheel cylinders, etc to rebuild the brakes. That's about it, except that I also got the "Open Drive" conversion from HRW (260 bucks). Great guys and everything is well made and fits perfectly. Guess I'm into the whole deal about $1200.00 us. Forgot to add: I also had the machine shop modify the ring gear and carrier assembly to fit the new gears If you have any other questions, just ask Jim Last edited by Kahuna; 06-02-2011 at 07:11 PM. Reason: added info |
06-02-2011, 04:05 PM | #7 |
This is the only picture that I have of the deal
Jim |
06-02-2011, 04:10 PM | #8 |
One last thing, Fairlane. On the HAMB, there is a great post, mostly by SamIam that deals with this and has/had many pics. I can't provide the link as the site seems to be down. But, search his posts, and I think you'll get a great deal of info. It may be in the tech files, but not sure
Jim |
06-02-2011, 07:09 PM | #9 |
06-11-2011, 10:40 PM | #10 |
Thanks Kahuna.
