Old 08-26-2018, 04:16 PM   #1
vintrex
vintrex's Avatar
Default Distributor wire question
I was going to swap out Dist. wires with a new unused uncut set of wires but wondered if the 6v Vs 12v would be an issue? All advice is appreiated...
vintrex is offline   Reply With Quote
Old 08-26-2018, 05:20 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Distributor wire question
If you are talking about spark plug wires (no difference)
Old 08-26-2018, 05:54 PM   #3
tubman
tubman's Avatar
I have been around the block a few times about this. Unless it is a factory correct restoration, I always go with Packard 440 solid core wire and Rajah spark plug terminals. I get them from the Brillman Company and have never regretted it. The positive "click" you hear when putting on a Rajah terminal on a spark plug is very satisfying.
Old 08-26-2018, 08:14 PM   #4
JSeery
JSeery's Avatar
I'm a 440 & Rajah fan as well.
Old 08-26-2018, 10:32 PM   #5
Tinker
Tinker's Avatar
Electronic ignitions excluded. you want solid core... outside spiral bound resistor wire for electronic ignition.
Old 08-27-2018, 10:44 AM   #6
vintrex
vintrex's Avatar
Sorry, yes I did mean spark plug wires. Thanks for the replies.
Old 08-27-2018, 11:20 AM   #7
B-O-B
B-O-B's Avatar
solid core & rajah ends from Brillman.
B-O-B is offline   Reply With Quote
