11-08-2020, 10:16 AM | #1 |
Banjo 39-40 hub flange difference?
I'm going to look at a banjo today for the purpose of needing unpitted axle bells
I'm needing a 39-40 but he thinks the hub Flange on his might be longer because of the drums? And might not be able to use wide 5 drums that I have? I was under the impression that 37-40 was the same? |
11-08-2020, 10:24 AM | #2 |
Re: Banjo 39-40 hub flange difference?
The bearing flange areas should be the same - no worries!
11-08-2020, 10:31 AM | #3 |
Great. Thank you
11-08-2020, 10:38 AM | #4 |
Post 41 axles are longer but the bearing surface is the same.
11-08-2020, 11:15 AM | #5 |
