06-04-2020, 07:36 PM | #1 |
Air Vent left of Steering Column ??
I got the cable for the Air Vent on the left side of the Steering Column BUT I have no idea where it goes. Can someone help me on this.I have got to get me a shop manual for this bird.
06-04-2020, 07:48 PM | #2 |
Re: Air Vent left of Steering Column ??
It ends up connected to a flapper valve on the fresh air duct in the engine compartment. It routed through the rubber biscuit that holds the wires that go through the firewall.
06-04-2020, 08:10 PM | #3 |
Paul's correct. It's a bit hidden behind the battery, and under the lip of the hood, so it's not obvious till you look. There's a bracket behind the battery that holds the end of the jacket, the flapper is 4-5" in front of it on my 55
06-04-2020, 09:59 PM | #4 |
When you locate the air duct (under the fender) where the bellcrank is for the damper, there should be a bracket sticking up on that duct which has a little hold down clip, held on to the bracket with a typical hex head lag-screw like they used on all the other heater sheet metal parts. If the little clip and screw are missing, let me know bu PM, and I will look in the garage, I think I have several of those with the screws.
06-04-2020, 10:02 PM | #5 |
I'm no T-bird expert but I thought the fresh air was the doors on the fender exterior on a '56. Is there a fresh air duct from the front as on a sedan?
06-04-2020, 11:01 PM | #6 |
06-04-2020, 11:02 PM | #7 |
Yes, there are a pair of fresh air scoops just behind the grille on each side. (photo 1)
The ductwork goes up over the front tires and comes out above each kick-panel on a '55, '56 & '57 T-Bird. They are just above the fender vent chrome grilles in the kick-panels of a '56/'57 T-Bird. The fresh air vent cables & knobs on the dashboard control the on/off flapper valves. One is just outboard of the battery, the other is outboard of and slightly behind the heater fan motor. (photo 2) Last edited by dmsfrr; 06-05-2020 at 08:38 AM. |
06-05-2020, 06:37 AM | #8 |
Thank you fellows. I will install today. Thanks again
06-05-2020, 07:33 AM | #9 | |
https://www.hotrodreverend.com/post/...tic-should-own these things are a gold mine
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
