Old 05-28-2020, 09:20 PM   #1
poolplayer1
Default 1955 Ford Ranch Wagon , Looking for part ID
I was greasing all fittings on front end suspension parts and noticed that the steering idler arm has alot of play on it.Probably worn out bushings but I am going to replace the arm,not just the bushings since its an origional part and has been there for many years. Does anyone here have the oem part # for this idler arm that I can get so i can start searching for it. The arm is for a mechanical steering,not a power steering. Thanks for your help.
poolplayer1 is offline   Reply With Quote
Old 05-28-2020, 09:49 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 1955 Ford Ranch Wagon , Looking for part ID
Most of the usual suspect suppliers have 'em., Mac's Eckler's, Concours Parts, etc, etc. No part number needed, just use the search term 1955 Ford idler arm.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 05-29-2020, 11:31 AM   #3
poolplayer1
Thanks for your reply and suggestions.
Old 05-29-2020, 01:21 PM   #4
dmsfrr
dmsfrr's Avatar
Originally Posted by poolplayer1 View Post
... The arm is for a mechanical steering,not a power steering. Thanks for your help.
If you hadn't guessed already, the idler arm for power steering is most likely different. The one on my little '55 is.
dmsfrr is offline   Reply With Quote
Old 05-29-2020, 03:22 PM   #5
Dobie Gillis
Yup, they are. I think they have a different shape due to the different drag link on a p/s car.
Old 05-31-2020, 12:04 AM   #6
Daves55Sedan
Daves55Sedan's Avatar
Yes the manual steering idler arm is completely different from the power steering idler arm. You may be in for a shock. Last time I looked in Mac's, they were only offering the manual steering idler arm bushings, NOT the idler arm.
But, since the idler arm and bushing threads wear against each other, it is highly recommended to replace both, since the acme threads on the idler arm may also be worn.
Daves55Sedan is offline   Reply With Quote
Old 05-31-2020, 12:11 AM   #7
Daves55Sedan
I just looked in an OLD (2017) catalog from Obsolete and Classic auto parts in Oklahoma City.
They showed the entire kit with idler arm, both bushings, rubber grease seals and two grease fittings Part# B5A-3352-A for manual steering $43.95.
BUT, it has been my experience that when one vendor runs out of stock of a specific item, the other repro suppliers also soon run out of it.
Their toll-free order desk is 1-800-654-3247 and specifically ask if they have it in-stock.
Old 05-31-2020, 05:29 PM   #8
poolplayer1
I did find the bushings for idler arm but not the idler arm kit,which has the bushings and seals.I called or checked online looking for the arm but nobody has it. Obsolete said that its out of stock and might be 6 weeks or so before they get anymore. There is a guy that said he has the one for 63 ford but not the 55. Its my understanding that only the 54-56 will work on this wagon.I guess I will wait and just check every once in awhile with the different part houses. Thanks Daves55 for your help with this part and also the other guys that added their tips and suggestions.
Old 05-31-2020, 05:52 PM   #9
Dobie Gillis
Try these guys:
https://cgfordparts.com/ufolder/ford...umber=B5A-3352
Old 05-31-2020, 06:58 PM   #10
Daves55Sedan
It might be a long wait. I ordered a new '55 speedo lens two years ago from TWO different repro parts suppliers. Still waiting.
Did you try Concours Parts, Dennis Carpenter, any of the other guys?
Old 05-31-2020, 07:34 PM   #11
paul2748
paul2748's Avatar
Try Kanter in NJ
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-01-2020, 04:11 PM   #12
5851a
https://www.ebay.com/itm/Steering-Id...b7f881e7cfd676
5851a is offline   Reply With Quote
Old 06-01-2020, 04:12 PM   #13
5851a
Only 1 left but with a price like that it may be available for awhile. Didn't see where it said manual or power.
Old 06-04-2020, 01:51 PM   #14
poolplayer1
I did see that particular idler arm on ebay for $236.00.A little too pricey,especially when others like Cgfordparts.com has it for $39.00. Also,Obsolete ford in Oklahoma sells it for $41.00. I have it ordered.I don't mind waiting 4 weeks at that price.
Old 06-05-2020, 08:30 AM   #15
Merc Cruzer
Merc Cruzer's Avatar
Not sure if Mercury is interchangeable, if they are, here are a few part numbers.
Merc Cruzer is offline   Reply With Quote
Old 06-05-2020, 08:43 AM   #16
54vicky
54vicky's Avatar
without going down to look at mine (both a PS one and non)I do not think that is a correct idle on the bay typical.from memory there should be a dip in it (both)
54vicky is offline   Reply With Quote
Old 06-05-2020, 09:52 AM   #17
Hot Rod Reverend
Hot Rod Reverend's Avatar
you need this...
https://the-hot-rod-reverend-s-class...thod_id=213483
very helpful manuals here!
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 06-05-2020, 09:54 AM   #18
Merc Cruzer
Both
Old 06-08-2020, 05:09 PM   #19
poolplayer1
Thanks for the info Merc Cruzer. The idler arm in the mercury looks like mine but the part #'s are different.Mercury is 3355 and mine is a 3352. Maybe the overall distance ( width) of the 2 arms is not the same. Also,according to cgfordparts and obsolete ford parts,there are 2 different part #'s for the 55,one for the PS type and one for the manual steering.
Mine is a manual.Also,thanks to Hot Rod Reverand for the link to the cd and also to the other guys with their opinions and suggestions.
