Old 04-23-2018, 12:09 PM   #1
Terry, NJ
Terry, NJ's Avatar
Default Dumb question! I just can't recall!
So, which way do the 6 universal (to transmission) bolts face, heads to rear or heads to the front and nuts in the rear? I should know, but I don't! Photos?
Terry
Terry, NJ is offline   Reply With Quote
Old 04-23-2018, 12:23 PM   #2
burner31
burner31's Avatar
Default Re: Dumb question! I just can't recall!
Does this pic help any?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-23-2018, 12:53 PM   #3
Terry, NJ
Terry, NJ's Avatar
Yes! But I don't think they're correct bolts. But thanks for posting this anyway.
Terry
Old 04-23-2018, 01:00 PM   #4
burner31
burner31's Avatar
Does not surprise me. PO did a lot of work/things on the car, not all of it to factory specs, he stopped working on the car in the early to mid '60's, and then it sat for the next 53 years.
Keith
Shawnee OK
'31 SW 160-B
Old 04-23-2018, 01:11 PM   #5
SeaSlugs
SeaSlugs's Avatar
EDIT PER DONS FINDINGS: The top center is different from the rest, i believe the top center is nut to rear, the rest nut to engine.
Reason being i dont think you can get a socket on the nut in the hole between the shift rail nubs.
I am also pretty sure the 2 clam halves the nuts are on top.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-23-2018, 01:17 PM   #6
Don Turley
Don Turley's Avatar
Illustration on page 350 of the Service Bulletins shows the castle nut on the forward side. However, the very top bolt appears to be the opposite direction.
Don Turley is offline   Reply With Quote
Old 04-23-2018, 01:36 PM   #7
Tom Endy
Tom Endy's Avatar
I believe the correct way to install these bolts is to put the head of the bolt between the two tunnel ears on the transmission tower with the nut on the back side. This way you can get a wrench on the nut. The other bolts go in the opposite direction.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 04-24-2018, 12:11 PM   #8
Ford1930
Ford1930's Avatar
This is how it looks on my 1929 Phaeton.
Ford1930 is offline   Reply With Quote
Old 04-24-2018, 02:36 PM   #9
J Franklin
J Franklin's Avatar
Are you working on the house roof? Nice shingles!
Old 04-24-2018, 06:15 PM   #10
Terry, NJ
Terry, NJ's Avatar
Thank you all> I was fighting with it and couldn't recall whether it was correct or not. Also, the bolt on top is just a hair shorter. You can't get the longer bolt in the hole.
Terry
Old 04-24-2018, 11:11 PM   #11
SeaSlugs
SeaSlugs's Avatar
Terry
Forgot about that tidbit lol. one of them live and learn moments
