10-09-2021, 02:08 PM | #1 |
36 Pickup cab to chassis
Good afternoon!
I'm getting ready to mount the cab of the pickup back onto the chassis. Is there anything that goes between the wood and the cab or anything between the wood and the frame? When I took all this apart, it was hard to tell what was there. Thanks in advance!!! Mark |
10-09-2021, 03:45 PM | #2 |
Re: 36 Pickup cab to chassis
Yes. Impregnated thick webbing goes in 3 spots on the bottom of the cab wood. Everywhere a bolt goes through the wood is where the webbing goes. It has a hole for the bolt to pass through. It is stapled on the wood. It is also used where the front of the cab matchs the frame. The webbing is about 1/8 thick. It is very similar in size to the rubber that is used to mount the radiator to the frame (but, it is not rubber).
Hope this helps. |
11-15-2021, 08:03 PM | #3 | |
if nec [email protected] |
11-15-2021, 09:50 PM | #4 |
I had a '36 half-ton 10 yrs back. Do you have the front shims? FRONT SHIMS ??????
