04-01-2012, 06:33 PM | #1 |
My milk shake oil is s-l-o-w-l-y going away.
I had a head gasket issue, and now have it sealed up with a new gasket (Brattons new style, pretty cool!). I am doing the usual warm up-cool down head re-torque routine, and change the oil after every session (third and last is tommorow). The oil is getting more clear, and now looks more like caramel syrup. I know, I should have just dropped the pan and also cleaned out the valve chamber to begin with. Anyway, I think my next oil change will be the last, and wanted any opinions as to wether you think the remaning water will eventually evaporate out with some driving. A mechanic buddy of mine once said that nobody ever ruined an engine by changing the oil too much, but I gotta stop eventually.
04-01-2012, 08:12 PM | #2 |
Re: My milk shake oil is s-l-o-w-l-y going away.
You can stop now!
I had a 39 Chev 216 with a cracked head and drove it for years until I sold it. In the time it took to watch a double feature at the drive-in enough water would accumulate in that cylinder that it would take 3-4 seconds just to squeeze the water out when cranking it. Unlike the Chev your car will cook the remaining water out with steady driving. If possible run it daily and long enough for it to heat up adequately and the oil should clear up in no time. |
04-01-2012, 08:54 PM | #3 |
Sounds like good advice to me. Make sure it gets and stays up to operating temp for a good twenty minutes before shutting her down. Which means, as I've stated in another thread, you need to take the scenic route on the shorter trips.
Rob Kellogg Cazenovia, NY |
04-01-2012, 09:11 PM | #4 |
I'll step out on the ledge. Sometimes they fix them selves. Stuck valve, some times not. What did you turque your head too? Was it plained? Just curious... Need to run them, sometimes hard
04-02-2012, 06:38 AM | #5 |
Hi Tinker, I torqued the head to 55 pounds. I had the head surfaced just enough to clean it up.
04-03-2012, 01:33 PM | #6 |
04-03-2012, 04:47 PM | #7 |
I'm not as comfortable with what's happening. Seems to me with all those oil changes and driving, the water should have been long ago burned off. Time will tell. I hope your OK.
04-03-2012, 05:05 PM | #8 |
Actually, I have not been driving the car between oil changes. I run it 20 minutes at a high idle so the engine and radiator are good and warm, then shut it off for a 24 hour cool down before re-torqueing. I drain the oil right after I shut it off, so the water stays mixed in and hopefully comes out. I can't believe there would be much more than a few ounces of water left at this point. It gets better with each change, so I am pretty confident with the new gasket.
