Old 04-29-2021, 05:49 PM   #1
Lefthander1930
Lefthander1930's Avatar
Default Fuel valve Victoria
Going to install a new fuel valve on my 31 Victoria. Going to drain tank & remove gas. Do I need to do anything after cleaning threads when installing new valve ? Teflon tape or anything like that .
Lefthander1930 is offline   Reply With Quote
Old 04-29-2021, 06:47 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Fuel valve Victoria
I'd throw the Teflon tape in the rubbish bin and use Permatex #3.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 04-29-2021, 08:03 PM   #3
Ruth
Install a pencil filter?
Ruth
Old 04-29-2021, 11:19 PM   #4
CWPASADENA
CWPASADENA's Avatar
I agree,
Teflon tape has caused many problems.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-01-2021, 12:24 AM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Not if you know how to use it. That said, more than once. I have pulled Blk iron gas line apart, and found 1/3 to 1/2 of the pipe blocked. Also seen big goobs of pipe dope inside the pipe, so the moral of the story is don’t put anything on the first two threads!
