Old 02-27-2016, 09:51 PM   #1
cw253748
cw253748's Avatar
Default Orwell health heater door
I have a Otwell health heater and I was wondering if I'm missing a spring on the top bolt to hold the door and deflector tight? Here is a pic. of the door. It was on my car with just the 2 bolts holding it on and the door was hard to move with the top bolt tightened.
cw253748 is offline   Reply With Quote
Old 02-28-2016, 08:31 AM   #2
Big hammer
Default Re: Orwell health heater door
Yes. I think(car isn't handy to look at) I used a longer bolt and nut to secure the housing, the extra length for a spring,door,and deflector. The door and deflector now stays put. I think I used a locking nut keeping tension on the spring, door, and deflector.
Old 02-28-2016, 09:38 AM   #3
CWilson
CWilson's Avatar
Mine has a spring. As you said, the spring holds it shut, or open, while still being able to open or close it.
CWilson is offline   Reply With Quote
Old 02-28-2016, 11:00 AM   #4
DougVieyra
DougVieyra's Avatar
Mine is an all-original, and it too has a spring. I think the consensuses is that you do need a spring.
DougVieyra is offline   Reply With Quote
Old 02-28-2016, 10:46 PM   #5
cw253748
cw253748's Avatar
Thanks guys for your help
Old 02-29-2016, 06:19 PM   #6
Benson
Benson's Avatar
Default Re: Otwell health heater door
I have had my Model 14 Otwell since '62. Do not know if it is original but the door and deflector are held on by a screw and spring to keep door and deflector from rattling and allow adjustments.
The screw is a shoulder type so that it "bottoms out" in the threads cut in the top mounting hole.
Then there is a lockwasher and nut on back (engine side) of fire wall to keep it tight.
