Old 03-24-2016, 11:31 AM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Picture of Zenith 1 Carb with a G
I don't ever recall seeing a "G" over the Zenith name before. Anyone know what it means?
This came from a homemade deer hauler I found in the trees at a garage sale a few years ago.
Motor runs like new.
Thanks
Old 03-24-2016, 11:52 AM   #2
jimalabam
jimalabam's Avatar
Default Re: Picture of Zenith 1 Carb with a G
A first also for me Tom. Maybe some of the others can chime in,,,
jimalabam is offline   Reply With Quote
Old 03-24-2016, 04:10 PM   #3
Carb Guy
Carb Guy's Avatar
I will look out in the shop at the carb bodies I have to see if i can come up with one like it. Hard to tell from the picture where the inlet is, either in the front or on the hood side like the A carbs, or in the front like B carbs.
Carb Guy is offline   Reply With Quote
Old 03-24-2016, 06:14 PM   #4
Tom Wesenberg
The fuel inlet faces the hood side, just like the common Zeniths do.
The front cover has the wide motor mounting flange for the 1928 solid motor mount.
Since Model A engines were used in Gleaner combines, I wonder if the "G" meant the engine or carb was destined for that machine?
Old 03-24-2016, 06:16 PM   #5
CarlG
CarlG's Avatar
They only used them on RED engines ??
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-24-2016, 07:43 PM   #6
Tiny
Tiny's Avatar
The G stands for gas.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 03-24-2016, 08:35 PM   #7
Pickupman
All Gleaner combines that utilized a Model A Ford Motor used a Kingston Carb.
Pickupman is offline   Reply With Quote
Old 03-26-2016, 08:42 AM   #8
Jwilli
Jwilli's Avatar
I have a Zenith 1 with the G above. Is that good or bad?
Jwilli is offline   Reply With Quote
Old 03-26-2016, 09:46 AM   #9
Carb Guy
Carb Guy's Avatar
Pictures of Zenith carbs Bottom & top With a "G" on them
Old 03-26-2016, 10:00 AM   #10
Carb Guy
Carb Guy's Avatar
Default Re: Picture of Zenith 1 Carb with a G on bottom & top
"G" on top & Bottom of Zenith carbs
Old 03-26-2016, 10:02 AM   #11
Carb Guy
Carb Guy's Avatar
JWilli. Nothing wrong just good Zenith Carbs
Old 03-26-2016, 10:12 AM   #12
RonC
RonC's Avatar
I believe some side bowl filters also have Gs
RonC is offline   Reply With Quote
Old 03-26-2016, 11:29 AM   #13
Carb Guy
Carb Guy's Avatar
Ron C
Yes I have worked on sidebowl filters with a "G" on them
Old 03-26-2016, 08:44 PM   #14
Bill Sherwood
a nice picture of a Zenith 1 with a "G" in the Judging Standards.
Bill Sherwood is offline   Reply With Quote
Old 03-27-2016, 11:27 PM   #15
Ron in Quincy
Ron in Quincy's Avatar
Tom,
I have a late Zenith-1 just like yours except the engraved "G" is on the back side of both the upper and lower housings. I also have a late Zenith-1 bowl that has a embossed "E" on the back side and no other markings.
The "G" on the front side may be like the Holley upper housing that only existed for 1 month, the "H" was sideways when the mold was made; the Holley is listed in the Standards; I have a complete restored Holley with the sideway "H".
Ron
Ron in Quincy is offline   Reply With Quote
Old 03-28-2016, 06:46 AM   #16
Tom Wesenberg
I guess there are a lot more carb markings than I'd realized. I've just never seen some of them.
Old 03-28-2016, 09:13 AM   #17
Rancho Deluxe
Rancho Deluxe's Avatar
I have been trying for a while now to find any one who knows something about this one, the way it is marked with the raised letters..
Rancho Deluxe is offline   Reply With Quote
Old 03-28-2016, 10:42 AM   #18
Ron in Quincy
Your raised Zenith-2 is a Holley made carb, it appears in the Standards, this way you can match the proper upper housing with your lower housing. By the way, your lower housing has a brass removable GAV needle seat.
Ron
Old 03-28-2016, 11:22 AM   #19
Carb Guy
Carb Guy's Avatar
As Ron said, the raised Zenith-2 is a Holley carb, it was only used Jan. , Feb., Mar., Apr. , of 1929
Old 03-28-2016, 12:16 PM   #20
Rancho Deluxe
I know all of that, who made it & when..But have Never seen a Zenith-2 with raised letters & a Raised "H" on the throat before.. It states in the Standards it had NO "H" on the throat !!
