Old 03-12-2017, 07:59 PM   #1
manmerc5519
Default 302 into 1953 ford
I am sorry about the mix up I meant to say 1953 instead of 54 ,but what I want to really know is which motor should I get 302 or 360 for the 53 . don't know yet if butch makes a conversion kit for the 360
manmerc5519 is offline   Reply With Quote
Old 03-12-2017, 08:16 PM   #2
1931flathead
Default Re: 302 into 1953 ford
302 is far a better motor
1931flathead is offline   Reply With Quote
Old 03-12-2017, 08:16 PM   #3
JSeery
JSeery's Avatar
Think you might do better asking on the HAMB.
Old 03-12-2017, 08:32 PM   #4
Jeff/Illinois
Jeff/Illinois's Avatar
We had a 302 in a '37 Ford pickup years ago, worked great and fit nicely too. Hope this helps.
A big block 360 FE motor will be a tighter squeeze.
Old 03-12-2017, 08:50 PM   #5
Ol' Ron
Ol' Ron's Avatar
I had one in a 52 PU. Fit like a glove. C4 and 8" with 3.06. Great driver, quick with good mielage. Doz this belong on the HAmb??
Old 03-12-2017, 09:40 PM   #6
Jack E/NJ
Jack E/NJ's Avatar
Ol'Ron>>>Doz this belong on the HAmb?? >>>
Well, it's not an SBC. So I guess, yes. Did I guess right? 8^) Jack E/NJ
Old 03-13-2017, 07:55 PM   #7
paul2748
paul2748's Avatar
I would go with the 302. Kits are available to install. I few mods to the engine and it will be a screamer.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-16-2017, 10:08 AM   #8
Milt/Las Vegas
Milt/Las Vegas's Avatar
You will need a rear sump pan from a pickup or van,be sure to get the special main bearing bolt with a 3/8 ths. stud purtruding from the head of the main bearing bolt and the dipstick and tube.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
