Old 10-24-2022, 07:28 AM   #21
BillCNC
BillCNC's Avatar
Default Re: 1930 stop light switch
Originally Posted by mcgarrett View Post
BillCNC,
It would certainly be worth cracking it open to see what's going on before shelling out $57.00 if it's something simple.
Download the guide I posted and compare the insides.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 10-24-2022, 08:09 AM   #22
Smokedtires
Smokedtires's Avatar
I made the adjustment and my brake lights are working properly again. Thanks for the help above, it's truly appreciated.
Smokedtires is offline   Reply With Quote
Old 10-24-2022, 08:11 AM   #23
Smokedtires
McGarret, I bet it just needs adjustment. I wonder if the adjustment changes as the brakes wear affecting the brake switch.
Old 10-24-2022, 10:44 AM   #24
Y-Blockhead
Y-Blockhead's Avatar
None of the vendors seem to have the US Made ones is stock anyway?
Good job Bill. Excellent write-up.
Old 10-24-2022, 01:18 PM   #25
mcgarrett
When you use the term "adjustment", do you mean to change the installation order of the washers to actuate the switch correctly? Please explain.
Thank you.
mcgarrett is offline   Reply With Quote
Old 10-24-2022, 01:36 PM   #26
BillCNC
BillCNC's Avatar
Thank you.
That, or you need to slightly bent the metal tab it engages with. Once open, work the rod back and forth and watch what's going on. You can hook a multimeter to the electrical contacts and check it while moving the rod.
Regards
Bill
Old 10-24-2022, 01:39 PM   #27
BillCNC
BillCNC's Avatar
Thank you
They have been out for awhile. I thought about getting a few of the cheapies and modify them for folks that don't want too, or cant themselves due to lack the proper tools.
Regards
Bill
Old 10-24-2022, 02:22 PM   #28
mcgarrett
Understood, thanks for the clarification.
