05-28-2016, 02:25 PM | #1 |
High Gloss Black Paint
What is the highest gloss true black enamel paint that sells in a rattle can? The rustoleum high gloss has a gray look when dry-- not true black. Thanks.
05-28-2016, 02:42 PM | #2 |
Re: High Gloss Black Paint
Try Krylon gloss black. I used it often, wet sanded and buffed it. Cheers
05-28-2016, 03:34 PM | #3 |
What are you using for a primer?
The primer can affect the surface hue. Then you also want ask which color black Yes, there are blacks with blue and yellow undertones and probably more. I have only experienced those 2. |
05-28-2016, 06:15 PM | #4 |
I have the same problem with rattle can black. Seems they all have a bit of a grey look to them.
05-28-2016, 06:18 PM | #5 |
I like Valspar Tractor and Implement gloss black. Sure looks black to me. Tractor Supply used to carry it but then changed to their own brand (probably to save costs). I have found it on Amazon (6 cans at a time).
05-28-2016, 06:38 PM | #6 |
Terry |
05-29-2016, 07:38 AM | #7 |
I like Duplicolor gloss black engine paint with ceramic
It goes on great , holds up well. The next best to using mixed paint and a gun Available at the common auto parts stores like advance.. Etc Larry Shepard |
05-29-2016, 07:51 AM | #8 |
Larry; I too have had good results with Dupliclor black. Pay careful to the subsequent recoat times, too soon and it does bubble up.
Brian French; 1930 Briggs Town Sedan |
05-29-2016, 08:56 AM | #9 |
Rustoleum appliance epoxy black.
05-29-2016, 09:30 AM | #10 |
I have had good results using SEM paints in rattle cans. A body shop person put me on to using these. NAPA caries SEM paint in rattle cans. I have also resently used the black sold by John Deere. I doubt they make it but that is where I found it.
05-29-2016, 12:42 PM | #11 |
Also a good automotive paint supply shop can put automotive paint in a spray can for
you. It won't have the hardner in it but it works well. |
05-30-2016, 04:06 AM | #12 |
05-30-2016, 05:42 AM | #13 |
As Mike said gloss black Appliance Enamel. Wish they made semi-gloss for carbs. It's impervious to gas
05-30-2016, 08:43 AM | #14 | |
05-30-2016, 09:48 PM | #15 |
Eastwood Chassis Black in gloss . Drys black , shiny and it's tough as nails . Available in a rattle can or in quarts .
05-31-2016, 07:32 AM | #16 |
I have had success with "VHT" (very high temp) Engine Enamel. Available at Auto Zone. Great shine, tough gas and oil resistant finish and again follow the re-coating directions.
