08-27-2021, 02:13 PM | #1 |
Any one have success with a repair??
Has anyone successfully repaired a fuel pump stand either welding, JB Weld, Devcon????
08-27-2021, 02:14 PM | #2 |
Re: Any one have success with a repair??
08-27-2021, 03:28 PM | #3 |
If you can get it clean enough a good TIG welder can probably fix that. If that is poor quality pot metal, there is a silver solder type product for pot metal that should work.
08-27-2021, 03:37 PM | #4 |
08-27-2021, 05:22 PM | #5 |
To try to avoid ruining it with solders or welds, I'd probably use high temp acrylic super glue just to get the two pieces back together like a busted piece of china. Then I'd probably try to strengthen it by smearing JB Weld on a steel el from Home Depot. Paint it and probably wouldn't notice it much.
08-27-2021, 06:19 PM | #6 |
08-27-2021, 08:07 PM | #7 |
It can be TIG welded.
08-27-2021, 09:18 PM | #8 |
May not be the same, but I had a good result using the pot metal brazing rods available online to repair a pot metal headlight bezel from my '68 Corvette about 30 years ago. It was still holding fine when I sold the car 5 years ago.
I think it's a crap-shoot depending on the original material composition and how lucky you are that particular day. |
08-27-2021, 09:29 PM | #9 | |
08-27-2021, 11:19 PM | #10 |
I might have one on the shelf that's not broken, depending on yr. PM me. You could braze it. It's a pot metal though.
The usual issue that warps these ears on the pump is the order you put it together. Certainly on the earlier motors with the baffle insert. The baffle goes in after the gasket. If you look at the bottom early pump stands they have a recess to fit the outer tube baffle. If you put the baffle under the gasket the gasket creates a hump and bends the ears and stresses the cast when cranking it tight. Popmetal and aluminum alloy is not very forgiving to being bent like iron. They do take a pounding too. Last edited by Tinker; 08-27-2021 at 11:34 PM. |
08-28-2021, 03:50 AM | #11 | |
I guess I understand your wanting to 'save' that piece, as I believe it's a relatively obscure 1932 piece, and likely hard to find, and harder yet to fork-over the cash for. I'm not sure there is a GOOD fix for that. You already know that the cheap-ass pot-metal material it's made from is garbage, and not even of current-day manufacturing quality. The biggest problem with those stands is the fragility of the engineering and shape of those things at the base. It ls obviously thin, and it has no swoopy risers or ribs transitioning that 90º angle to lend support. On top of that, ALL of those thin flanges on the bottom of those stands appear to NOT be flat across the bottom, but with an ever-so-slight arc built-in. This leads to the casting being stressed when bolted-down, the tension of such lending to bending the two ears downward, stressing the exact area where yours cracked. One more very important consideration is the constant pounding that the cam puts on those two ears every cycle of the pushrod as it applies pressure to pump the diaphragm, like maybe as many as 1,500 cycles per minute while just going down the highway at a fair clip. I just can't imagine a "dependable" way of repairing one of those. DD . |
08-28-2021, 08:34 AM | #12 |
>>> I just can't imagine a "dependable" way of repairing one of those. DD>>>
Yep, if it were mine & if I cared about looks, I'd fake it with glue and an electric pump hidden away somewhere. 8^) |
08-28-2021, 08:46 AM | #13 |
I suspect that it is a zinc based casting which would make it very difficult to TIG weld as the zinc wants to boil off creating a porosity problem plus zinc fumes are not good for you.
If I were to try that repair I would look for one of the welding rods made for zinc/pot metal repair and use an OA torch. |
08-28-2021, 09:07 AM | #14 |
If you could copper plate each piece, you could then solder it together at the break adding enough solder material to make a nice fillet to beef up the area. A GOOGLE search may help. Read thru all of this info, especially the Jeff Lilly posting. It may give you some ideas.
https://www.google.com/search?q=can+...hrome&ie=UTF-8 I wonder if you could use 3D Printing to make a model of your base and have it cast. Or is there a way to encapsulate your base at the break so as to reinforce it? Last edited by 19Fordy; 08-28-2021 at 10:19 AM. |
08-28-2021, 11:30 AM | #15 |
I have an extra from a 34 if it’s the same.
Tim Carlig |
08-28-2021, 05:14 PM | #16 |
Get a piece of 1.5 to 3 mm bit of stock cut it to the shape of the base ,get some exhaust tube or fabricate something the same size as the inside of pump cut a 2" or so hole in the stock base and two stud holes weld the tube on the inside to the base stock were it wont interfere .Slide the arrangement up inside the pump ,mark around the tube were the hole is in the side ,cut that out with a hole saw .Glue it altogether and inside , say PC7 or block repair mix ,Glue the tube inside also ,You might be able to screw it inside somewhere , File it all tidy and you wont see much dont over tighten it should be good to go
08-28-2021, 06:01 PM | #17 |
I would think that he would also have to add the same amount to the fuel pump push rod.
08-28-2021, 06:07 PM | #18 |
Those castings can not be welded satisfactory, I have a brass spare fuel pump stand here chrome plated which I had cast many years ago it needs parts from another one to finish it of.
08-28-2021, 07:55 PM | #19 |
Robert....send it with the other parts, I think I can make the repair.
Charlie ny |
08-28-2021, 11:48 PM | #20 |
Yes good catch ,
