03-13-2021, 05:05 PM | #1 |
1933 Ford
Vin tag on a 1933 Victoria is 1532. Does anyone know when this was built? Tom
03-13-2021, 05:13 PM | #2 |
Re: 1933 Ford
Where, on the vehicle, is that "Vin tag" located? DD
03-13-2021, 05:54 PM | #3 |
Re: 1933 Ford
Tag on firewall
03-13-2021, 05:59 PM | #4 |
Re: 1933 Ford
740-L-1532 is body number tag
03-13-2021, 06:35 PM | #5 |
Re: 1933 Ford
That's correct..."body number" was only used for bookkeeping during production process. TRUE "VIN" numbers didn't come about in the US until 1968. Your "Serial Number" that is used for vehicle identification and registration purposes is hand-STAMPED into the top surface of the driver-side frame rail in three locations. The main location is in the area of the steering box, and CAN be anywhere between the firewall and the front crossmember. It will likely begin with a STAR, and then fall between "18-203,127" and "18-457,477", with another STAR after the last digit. The numerical sequence is normally stamped again on the top surface of the left frame rail at about the driver seat location, and then a third time atop the frame rail kick-up at left rear frame rail. That entire serial number (with STARS) is also stamped into a pad at the top, front of the ORIGINAL transmission housing. DD |
03-13-2021, 07:14 PM | #6 |
Re: 1933 Ford
03-13-2021, 07:19 PM | #7 |
Re: 1933 Ford
Please see the other thread for a perspective of where body #1532 fell in relation to the total '33 Victoria production in the U.S.
