05-01-2021, 03:09 PM | #1 |
First time electrical problem
First time ever since I have had this car for 50 years, electrical issue. Last fall at the end of the season... battery went dead. Old battery I figured. Just now installing a new battery, I notice a tiny spark as I connected the last terminal... Uh Oh !
My VOM shows a 4 amp draw. So what on a 31 Coupe draws 4 amps? After diddling around with a bunch of wires, I find an intermittent connection at the push lock ignition switch. With the switch pushed in (off) wiggle the key and occasionally get a sustained "on" connection. So now to pull the whole darn cable/ switch assembly and see what's going on. Answer to the question what draws 4 amps? ... the coil. Joe B |
05-01-2021, 05:21 PM | #2 |
Re: First time electrical problem
Dick Crabtree can fix that right up for you.
05-01-2021, 06:33 PM | #3 |
Good afternoon...Your pop-out system needs some love! You can send it out for a re-build and use a simple two position key switch (on-off) in the meantime...Bratton's and Burts have good ones and Snyders as well, also Sammy at Arizona Model A. I had mine re-built some years ago and never got around to putting it back in the car! Ernie in Arizona
05-01-2021, 06:48 PM | #4 |
How to contact Mr Crabtree? or does sell through a supplier or on line
Joe |
05-01-2021, 08:22 PM | #5 |
The four amps is the current flow through the ignition coil. When you switch the ignition on and the points should happen to be closed the circuit will draw a nominal four amps through the coil. A short in the pop-out cable or at the ignition switch would put a ground on the coil and it would do the same.
I had the pop-out cable for my Grandson's 30 Tudor rebuilt by Dick Crabtree, He is in Missouri 605-487-7229. Tom Endy |
05-01-2021, 09:08 PM | #6 |
05-01-2021, 09:38 PM | #7 |
Dick Crabtree is in Pickstown, South Dakota, on Missouri Drive.
[email protected] Excellent work at very fair prices. Chris W. |
05-01-2021, 11:14 PM | #8 |
Thank you guys. I'll make that contact
Joe B |
05-02-2021, 10:02 AM | #9 |
FWIW, w/the engine running the current will be down to about 1 or 1&1/2 amps.
