11-06-2016, 12:19 PM | #1 |
Model A Frame
I have a spare model A frame that has been in dry storage for over 50 years for a someday project. I no longer have a use for it and need the space in my shed. How do I tell what year it is and what is a fair price for it?
Thank you in advance. |
11-06-2016, 12:25 PM | #2 |
Re: Model A Frame
What is the number stamped on the frame?
Bob |
11-06-2016, 12:38 PM | #3 |
Re: Model A Frame
I will have to look and get back to you.
Is the number stamped on the wide rail right behind where the battery sits? |
11-06-2016, 01:02 PM | #4 |
Re: Model A Frame
yes
www.whidbeymodelaclub.com |
11-06-2016, 01:08 PM | #5 |
Re: Model A Frame
The frame number is stamped on the top of the frame rail, just to the rear of the left front cowl bolt hole.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
11-06-2016, 02:12 PM | #6 |
Re: Model A Frame
11-06-2016, 02:36 PM | #7 |
Re: Model A Frame
I pulled my frame out in the sunshine and so far I can not find any number.
I am going out again to see what I can find. I will keep you posted. |
11-06-2016, 02:45 PM | #8 |
Re: Model A Frame
Try wire brush and then white chalk, or a pencil rubbing lead sideways on paper laid over number.
11-06-2016, 02:51 PM | #9 |
Re: Model A Frame
Figment has described the correct place to look for the number: on the top of the left (ds) frame rail, not the cross member behind the battery box.
11-06-2016, 03:10 PM | #10 |
Re: Model A Frame
Still can't find any number. Has some surface rust, but mainly original black paint.
11-06-2016, 03:13 PM | #11 |
Re: Model A Frame
Canadian frames were not numbered.
11-06-2016, 03:21 PM | #12 |
Re: Model A Frame
Post a picture of the front cross member and the emergency brake cross shaft.
You can also check our Steve Plucker's article. http://www.plucks329s.org/pdf/frame/..._Assembly2.pdf Bob |
11-06-2016, 03:32 PM | #13 |
Re: Model A Frame
Another pic of location .
11-06-2016, 04:35 PM | #14 |
Re: Model A Frame
Thank you, after supper I will go out and look again.
I just returned from a 20 mile ride in my 1930 coupe along the Mississippi River Road. First on the Minneapolis side of the river then crossed over a bridge then along the St. Paul side parkway system, then back home following the Minnehaha parkway. |
11-07-2016, 01:33 AM | #15 |
Re: Model A Frame
Look for the hole where the steering comes out. If you have the same hole on the passenger side it's a 28-29
11-28-2016, 10:27 AM | #16 |
Re: Model A Frame
I'm looking for a good 28-29 frame Jim. Live close to Rochester, Mn
11-28-2016, 03:21 PM | #17 |
Re: Model A Frame
It may be further back than the pointer indicates. The number on my late '31 Tudor was beyond the crewmember.
