Old 09-18-2019, 01:48 PM   #1
Bulligen
Bulligen's Avatar
Default 1932 Ford Pickup wood fasteners
Is there a outlet for the Large headed carriage bolts that fasten the wood to the back of the cab. Thanks guys!
Bulligen is offline   Reply With Quote
Old 09-18-2019, 04:17 PM   #2
Krylon32
Default Re: 1932 Ford Pickup wood fasteners
I got mine from Mack Hills in Missouri
Krylon32 is offline   Reply With Quote
Old 09-18-2019, 06:43 PM   #3
DavidG
DavidG's Avatar
With respect, it's Mack Hils, not Mac Hills.
Old 09-18-2019, 10:19 PM   #4
Bulligen
Bulligen's Avatar
Thank you gents !
Old 09-18-2019, 10:27 PM   #5
DavidG
DavidG's Avatar
P.S. Given the head configuration, they are known as step bolts, not carriage bolts.
Old 09-18-2019, 10:57 PM   #6
34pickup
34pickup's Avatar
I bought SS carriage bolts from Lowe's. Unless you are doing an actual restoration, they are close enough that the difference in head size isn't noticeable. They fit just like the rusty ones I removed.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 09-18-2019, 11:04 PM   #7
Tinker
Tinker's Avatar
I saved a few from my 38. The rest. cab back had to use repo. The actual bolts are very different. Heads aren't domed and have a square hold on top for the bed. 3/8 ratchet is close but small. Used a window crank off a 1920s home window for the 38. Worked well with the "chatter rods" also. At least on my 1938.
Old 09-20-2019, 08:04 PM   #8
Manuel
Does anybody have pictures of the bolts?
Manuel in Oz
Manuel is offline   Reply With Quote
Old 11-26-2022, 06:17 PM   #9
uncle buck
uncle buck's Avatar
Manuel in Oz
Bringing this to the top…
Michael Driskill , do you offer these?
@35fordtn
uncle buck is offline   Reply With Quote
