Old 04-07-2014, 05:22 PM   #1
josh1331
Default Wipers don't work
Heard a hiss onmy-1941 super dex. Turned knob hiss stopped but no movement that I can see. Any tips would be appreciated. Don't mind vaccum wipers ,my car has two wiper blades by the way. John
josh1331 is offline   Reply With Quote
Old 04-07-2014, 05:35 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Wipers don't work
Your wiper motor paddle has dried out. You can try lubricating it by spraying oil through the vacuum intake on the motor whil operating the blades by hand. You can fool with the thing in other ways also, but eventually bite the bullet and send the motor out to be reb uilt. Kent Jaquith replaces the old hard paddle with neoprene for a lifetime fix:
Kent Jaquith, 2633 SW Obsidian # 15, Redmond, Oregon (541) 923-4319
Clean-Sweep Windshield Wiper Motor Service, Sales and Rebuilding
Alan
Old 04-07-2014, 09:42 PM   #3
josh1331
Thanks Alan. Finally got to ford barn thks for address to repair John
Old 04-08-2014, 08:14 PM   #4
BL in NH
Fricken Wiper Service on Long Island, NY I believe, More local than cross country and does good work. Believe he is still in business.
BL in NH is offline   Reply With Quote
Old 04-08-2014, 10:52 PM   #5
ford38v8
ford38v8's Avatar
BL, When local means "walk it through", that's understandable, but the Post office is local wherever you are. Ficken does have a good reputation, but is not a Ford enthusiast as Kent is. I'll trust my Early Ford work to a long time V8 Club member in very good standing who is dedicated to maintaining that reputation.
Alan
Old 04-09-2014, 12:09 AM   #6
Graeme / New Zealand
Graeme / New Zealand's Avatar
It is probably gummed up with old hard grease .Pull it apart clean it all up in thinners,lubricate the paddle with Vaseline put it back together in reverse. Very simple to do, it is not complicated, doesn't take much time and any "dumba*ss" should be able to do it. Give it ago yourself. I have done two of these, there's nothing much you can do wrong, it will be cheaper and you will have a sense of achievement.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 04-09-2014, 09:21 AM   #7
Old Henry
Old Henry's Avatar
GB
Same here. I did the same although Vaseline seemed a bit thick. I used distributor cam grease and it seemed to work better.
Old 04-09-2014, 10:02 AM   #8
TJ
TJ's Avatar
X2 for Kent Jaquith. He's fixed several for me and they work just as good as any electric wiper.
Old 04-09-2014, 12:01 PM   #9
Steves46
Steves46's Avatar
In addition to the excellent feedback, spray some white lithium grease on all the pivot points on the wiper arms that connect to the motor. I did this on my 46 and they run like electric wipers.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 04-09-2014, 11:41 PM   #10
josh1331
GB , plan to do just that nothing to lose john
Old 04-10-2014, 08:59 PM   #11
Rich Overton
About five years ago had the same problem on my '48. Started checking some Ford sites and I can't remember which one but it said to shoot a small amount of ATF into the intake side. Worked like a charm and they're still going as strong as new.
Maybe you'll be as lucky.
Rich O.
Rich Overton is offline   Reply With Quote
