01-22-2019, 01:20 PM | #21 |
Re: Dual 94s one really sucks, one not so much
Thanks,
Flatjack9, I am at sea level and do have 50s I could put in in the future once I road test it. Tubman, The choke plate is in place just not hooked up to the primary carbs choke. It basically just stays open as far as I can tell. I should have been more exact in my description. Ol'Ron, I have a mallory breakers less electronic with advance weights controlled by springs and adjusted with an interchangeable bushing. In my case it only came with one set of springs and one bushing installed. It is a crab style and mounted to the front center camshaft. I took the distributor apart and cleaned all the contact surfaces. And again I have an 8BA block. Its not the loadomatic vacuum advance control distributor that was designed for the 8BA. My dual 94 also do not have the combined venture and port vacuum option. Another note, I also noticed I have one stripped blot in the main body in the larger nozzle bar clamp securing the nozzle bars down. I will try to re thread to one bolt size bigger to do a band aid fix. I still need to see if there is enough meat in the main body to do this. The stripped bolt is in the primary with the choke hooked up. The 94 that has very little suction sound. Regards Last edited by RandyMettler; 01-22-2019 at 01:55 PM. |
01-22-2019, 01:27 PM | #22 |
I surely would go with the 50's if not 51's. If that nozzle bar does not seal to the body, you will not get proper fuel flow.
02-07-2019, 03:50 PM | #23 |
I have since ordered, received and installed one of CharlieNYs fuel pumps and took Bubbas Ignitions advice and ordered and received a Deluxe Carburetor Airflow Meter. When testing my dual 94 setup on Olfenhauser intake on my 8BA, the primary carb registered 11 kg/h while the secondary non choke 94 read pegged at what I am guessing is well above the 30 kg/h mark. The secondary is also the carb that is audibly sucking in air much more than the primary. Also when the engine was turned off with the air cleaners removed, the secondary 94 had a mist of vaporized gas swirling in the air horn assembly.
The Deluxe Carburetor Airflow Meter has two holes at the base, see pictures. I am not sure if they need to be plugged when testing? The optional rubber boot plugs these holes when installed, but is not compatible with the 94s airhorn. When rubber boot is not installed they are left open, which is confusing to me. I am not really sure what the plastic baskets for. There were no instructions with the unit. I didn't find youtube videos explaining this. The engine stumbles and backfires out of the exhaust when throttle is applied. Regards |
02-07-2019, 05:52 PM | #24 | |
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
02-08-2019, 11:31 AM | #25 |
I struggled with my dual 94s on a 59ab for months taking apart, adjusting, etc... very similar problem. I concluded worn throttle shaft. Sent Charlie NY the carbs, he fixed carbs including throttle shafts...problem solved. Good luck.
02-08-2019, 11:44 AM | #26 |
02-08-2019, 01:28 PM | #27 |
First of all, thanks to all of you who have given your time and advise. I really appreciate that.
In regards to LQQKER's previous post: "I struggled with my dual 94s on a 59ab for months taking apart, adjusting, etc... very similar problem. I concluded worn throttle shaft. Sent Charlie NY the carbs, he fixed carbs including throttle shafts...problem solved. Good luck." When I have difficulty getting the car to fire up, I have noticed gas leaking from the throttle shafts on both 94 carbs. The gas is not visible once the car is started. I am guessing because of the vacuum created by the pistons and the heat from the engine. My question is, are the gas leaks an indication of worn throttle shafts? Can simply purchasing new shafts stop the leaks? One of the 94s is a Chandler Groves. Do the bodies of the carbs also wear with time? If so, the reason I ask, do companies such as Vintage Speed and Charlie NY make larger throttle shafts that require specific size drill bits to "freshen up" the carbs worn out bodies? Last edited by RandyMettler; 02-08-2019 at 01:34 PM. |
02-08-2019, 07:44 PM | #28 |
Randy,
.005 over size shafts are available from Speedway. To fit one of these shaft right you should use a LINE REAMER. Unless you are really lucky a drill bit won't do the job, you will get an egg shaped hole. A reamer provides the best opportunity for a round and straight series of holes.....remember the shaft hole is actually three holes. One hole on the drivers side of the base , one in the middle and one on the passenger side.......all must be round and in line. These carbs are pretty basic but usually when they give a guy trouble are not always simple to diagnose and repair. Charlie |
02-08-2019, 07:51 PM | #29 |
Chandler Groves is a first yr and one yr carb, thinking best for a 38 restorer. Design was taken over by Holley due to manufacturing short commings by Chandler Groves. (or so it goes)
. Last edited by Tinker; 02-08-2019 at 08:01 PM. |
02-08-2019, 08:35 PM | #30 |
Tinker, it was another example of Henry Ford's sharp business practices, contracting with CG in such a way as to guarantee failure and Ford ownership of the patent. The old man always got the upper hand in his contracts.
The CG logo appeared on the '38 carb with no model number, and continued into '39 model year with the 91-99 model number etched onto the CG molds, and manufactured by Holley. New molds with Ford script came in mid year. I believe the failure to deliver was a deliberate built in confusion of model year vs calendar year in the contracts.
Alan |
02-08-2019, 08:49 PM | #31 |
Alan, I knew as much (or little) that Chandler Groves was contracted to design and manufacture for a year, but also giving Ford rights to take the design, after the first year if numbers couldn't be met.
Sounds about right though. Bill Gates was also a very lawyer savoy business man also. When windows came out he contracted HP "that every computer they made, they would pay a price"". At the time that made sense, since windows was what everyone wanted. Once Linux was requested by consumers, HP started putting linux on them. But still had to pay Bill (microsoft) for every computer sold, due to contract. Always nice to have a few lawyers in pocket I guess. Charlie probably could get you straighten out, one way are the other. Advice/parts or service. Last edited by Tinker; 02-08-2019 at 10:31 PM. |
02-08-2019, 11:01 PM | #32 |
When I set up my Strombergs 97s (I have used Holleys), I first check that the throttle plates are closed with the idle screw backed off. I then measure the throttle shafts center to center on the drivers side with the carbs installed on the manifold. Using a pair of dividers or a ruler, I set the center to center distance on the arms that the linkage on the drivers side mount to and set the connecting linkage to the same center to center distance. The linkage should go together without further adjustment. I then set the idle stops on both carbs. The linkage from the firewall goes to the front carb. Start the engine and adjust both carbs for idle mixture followed by the throttle stop screws - make sure the throttle stops hit at the same time. I have had good success with this procedure.
02-08-2019, 11:04 PM | #33 |
It may sound silly or nostalgic, even though ford ripped off Chandler Groves, but I am proud to have one Chandler Groves 94. It came with the purchase of my ford. I wish I had a matching set.
Charley NY, Please email me at [email protected] to discuss sending you my 94's to be rebuilt properly. I get that simply taking a drill bit to the carbs could make things worse. Regards Last edited by RandyMettler; 02-08-2019 at 11:15 PM. |
02-08-2019, 11:08 PM | #34 |
Randy if you want a match pair of chandlers I can send ya the match one to yours. or drop ship it to Charlie. PM me if you're interested.
02-08-2019, 11:19 PM | #35 |
Please email me at [email protected] to discuss condition and price of your Candler Groves 94.
Regards I am old school, don't know what "PM" is Last edited by RandyMettler; 02-08-2019 at 11:30 PM. |
02-08-2019, 11:24 PM | #36 |
Will do Randy. I'll go out tomorrow and send you some pictures of my chandlers. See if you can match them up.
If that's the direction you want to go. Last edited by Tinker; 02-08-2019 at 11:35 PM. |
02-09-2019, 12:10 AM | #37 |
Randy and Tinker......
However you guys work things out is fine with me for sure. I will mention here I have an unlimited supply of 94's many many are Chandler Groves including some discussed here. I can happily match yours N/C. If we do end up doing business just be sure you send me both your carbs......ck your emails Charlie ny [email protected] |
