01-20-2019, 09:31 PM | #1 |
passenger side of the motor running 20 degrees hotter than driver side
I took off the heads and intake to adjusted the tappet lash.
After reinstall, I did temp readings with an interfered gun and the cooling on all cylinders front to back seems to be even. The odd thing is the passenger side of the block is running roughly 20 degrees warmer than the driver side. An again, all cylinders on passenger side running even, but 20 degrees hotter than the driver side. The water pump on the passenger side seemed smooth and tight when I had it off, just like the driver side pump. I noticed a slight tapping on cylinder 4. I located the tapping with a long screwdriver on the head near #4s plug. I don't believe I had the tapping before adjusting the tappet gap for the valves. Could the tapping be causing overheating and poor valve gap adjustment? It starts cold, but is very hard to start once it starts to warm up. This time the hard starting is even at temperatures as low as 150, so not vapor lock/boiling fuel in the bowl. I bench tested my coil and according to my numbers with a volt meter, the manufacture tech said it was on its way out. Although he had to verify with his supervisor, ten minutes later on hold. I was not really that confident in his knowledge as a tech advisor as he didn't understand my bench test numbers as what was under or over spec. This was MSD home page and their tech! I know they produce quality parts, but to me this was disappointing. Are all companies cutting corners this hard? Could a suspected lazy coil cause hard starting and overheating? Regards Last edited by RandyMettler; 01-20-2019 at 09:54 PM. |
01-20-2019, 10:06 PM | #2 |
Re: passenger side of the motor running 20 degrees hotter than driver side
It is fairly common for one side to run hotter than the other.
01-20-2019, 10:42 PM | #3 |
Its not uncommon , 20 degrees perhaps a little on the high side .. Did you shave yours heads or have them faced , did you check clearance? possibly the piston touching the head..just a thought. And yes poor adjustment to the valve[s] or sticking ..
01-20-2019, 10:52 PM | #4 |
One side hotter than the other is pretty common. Don't fret over it.
01-21-2019, 09:23 AM | #5 |
Ideal situation to make a hot water heater more efficient
01-21-2019, 10:25 AM | #6 |
01-21-2019, 11:28 AM | #7 |
tubman, I am sure you are aware that there was a redesign of the original 8BA head gaskets to actually divert more water to the rear of the block. Wonder if that creates a temperature differential?
01-21-2019, 11:45 AM | #8 |
The same situation exist with the 59a blocks, don't think it is a head gasket issue.
01-21-2019, 01:34 PM | #9 | |
"JSeery", I'm not too familiar with the earlier flatheads, but the Ford engineers made some pretty sophisticated changes in water distribution on the 8BA's for cooling purposes, why not to make the heater work better? Please note : This is all speculation on my part, but it would explain this often observed phenomena. |
01-21-2019, 01:46 PM | #10 |
Talkwrench
"Its not uncommon , 20 degrees perhaps a little on the high side .. Did you shave yours heads or have them faced , did you check clearance? possibly the piston touching the head..just a thought. And yes poor adjustment to the valve[s] or sticking .." Thanks for the response I did not shave my heads or have them faced. I pulled the heads to check valve lash, cleaned up the surfaces, bought new copper gaskets and reinstalled. I adjusted the valve lash to 11 intake and 13 exhaust for 8BA block. Is the ticking more likely a piston issue and not a valve noise? I plan on pulling the intake and passenger side head again and check valve lash on the intake and exhaust for #4 cylinder. Is it possible to visually see "sticking"? When rotating the crank all the valves seem to operate smoothly, but I am new cracking open engines. Regards |
01-21-2019, 04:00 PM | #11 |
After first reading this thread, I fired up my 40 and let it run at a fast idle for about 45 min. until stock temperature gauge needle was on the middle line, meaning Normal. Then, with an infra red temp gun, I took a reading at each of the spark plug cavities on the each head near where the plug screws in. Both cylinder heads gave the same reading of 180 to 182 degrees. The temperature at the front and rear of the heads were almost the same -both right and left. Heads are aluminum radiator is Walker with mechanical fan. Ambient temp. is 67 degrees F. When I bought these heads in 1999 Mark Kirby made them for use without thermostats.
Car was in the garage. Maybe under load on the road things would change. Last edited by 19Fordy; 01-21-2019 at 04:09 PM. |
01-21-2019, 09:40 PM | #12 |
Usually you just check without a head gasket, rotate and see if anything touches. After all these years you just never know what someone has done. The copper gasket might be just slightly thinner than what you had [ but unlikely ]?
Now did you go through the three heat cycles and re torque the heads? If its no.4 it might well be just the fuel pump rod ticking too. Incorrect timing can cause heating issues.
01-21-2019, 10:01 PM | #13 |
Talkwrench
I have gone through two cycles and the leaks are almost gone. Just leaking a little out of the passenger water pump. I re-torqued one time to 40 ponds and the head bolt leaks have seemed to stopped. I was wrong, the ticking is not from #4, it seems to be coming from lower. When adjusting the valve lash I dropped a nail into the the exhaust valve and had to remove the driver exhaust manifold and use a magnet to retrieve the nail. I reused the existing exhaust manifold gaskets and think that may be the cause of the ticking. |
01-21-2019, 10:03 PM | #14 |
An Exhaust leak does sound a lot like a lower end "tick".
Did you have the "tick" before the change? Everytime you make a change, observe. A engine log of changes doesn't hurt. I keep one in the glovebox that's 8yrs now. Oil changes, plugs, compression, etc....etc.... |
01-21-2019, 10:10 PM | #15 |
Tinker,
No ticking before. But I have true dual exhausts with glass packs and my car was fully assembled. Now the front consists of a frame, radiator and fully assembled engine. Ticks could be more noticeable. My next step is to replace the driver side exhaust manifold gaskets. I just hope it is not a crankshaft tick. Last edited by RandyMettler; 01-21-2019 at 10:19 PM. |
01-21-2019, 10:20 PM | #16 |
Rod or crankshaft problems usually don't tick. they slap/thunk.
Been thrown off a few times by the fuel pump rod doing it's job. If your looking for a sound, you'll find it. I do like that Lhead sewing machine sound. Exhaust leak seems most probable. Less you through a bearing sitting. One thing at a time is best. Hard to track 3 changes at a time on a running engine. . |
01-21-2019, 10:22 PM | #17 |
Tinker,
That's exactly what it sounds like, a faint sewing machine sound, more so on the driver side. |
01-21-2019, 10:25 PM | #18 |
Sounds like a flathead running... but you never know. I like that sound.
reusing exhaust manifolds gaskets are not advisable. . Last edited by Tinker; 01-21-2019 at 10:52 PM. |
01-21-2019, 10:55 PM | #19 | |
Okay... guess the question and answer changed.... Dual exhaust won't matter. Follow your changes....... Loud exhaust just make it harder to pinpoint. |
01-22-2019, 12:28 AM | #20 |
40 Lbs..? should be torqued at 50 lbs. And three times.
