07-05-2015, 01:52 AM | #1 |
some questions about 68B cabriolet
My dad want to finish to paint and to assemble his early 1930 convertible cabriolet. (help needed...)
_ He don't know which color (dark or light) to paint the cowl door post and the inside top cowl around the windshield. _ the window door garnish were red with a little bit of black. Windshield garnish are dark body color. Original ? _ some little parts seem to be missing : . something fixed on the door wood, between the glass and the outside door molding. Upper door seal ? . the parts where window slides. Felt or steel ? Thank you for your help. |
07-05-2015, 03:25 PM | #2 |
Re: some questions about 68B cabriolet
Nobody has one or two idea ? He would like to paint it this week.
79 years old and always in a hurry. Thanks. |
07-05-2015, 03:42 PM | #3 |
pm sent
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
07-06-2015, 03:28 PM | #4 |
my answers are based on having a 68A, not a 68B; but the bodies are in many ways the same from the back of the cowl on back, as I understand it.
_ the window door garnish were red with a little bit of black. Maybe faded or worn Mahogany graining? - something fixed on the door wood, between the glass and the outside door molding. Upper door seal ? Yes -the parts where window slides. Felt or steel ? Both, well not steel. A short piece of felt channel at the back edge of the window frame. ...and a long strip of nickel plated, stamped/formed brass at the front of the window frame |
07-06-2015, 04:45 PM | #5 |
Thank you 160B and Russ B !
Somebody sells upper door seal and rear felt channel ? |
07-06-2015, 05:01 PM | #6 |
http://www.cabriolet.modelahouse.com/cgi-bin/pictures You're probably talking about this for the "rear felt channel" http://www.snydersantiqueauto.com/ca...lace-retainers There is no door top on a cabriolet, so no Upper door seal. Go to this link for parts available for cabriolet: You may be missing the specialized rubbers that go between the folding top behind the door window and the body on pg 3 for example... http://www.snydersantiqueauto.com/se...12&q=cabriolet
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
07-06-2015, 05:02 PM | #7 |
Upper door seal may be from Snyders or Brattons, I don't recall, maybe same as for four door sedan. The rear felt may be harder to find. I would call the Cabriolet Club 936-441-8209, Larry, though he is not making/supplying many parts anymore, he may give you a lead. Consider joining the club. Some of the back issues have good info otherwise unavailable.
07-07-2015, 09:40 AM | #8 |
Get a copy of the Model Paint Guide. There are tables in the guide that tell you what colors the various parts of the car are painted. Ed
07-07-2015, 03:04 PM | #9 |
Interesting website !
E-mail send to Snyder. I received a copy of the paint guide. Thank you everybody ! |
Thread Tools | |
Display Modes | |
