03-10-2023, 11:53 AM | #1 |
Engine Srand
When .mounting a model a engine on an engine stand, which bolt holes on the
engine should be used? Thx. |
03-10-2023, 12:49 PM | #2 |
Re: Engine Srand
Here are photos of common variations that pickup the water inlet mounting holes and a support feature down to the pan rail.
The weight center changes as parts are added/subtracted making the assembly harder to rotate.......pick one the is more centered when the engine is fully assembled making it easier to rotate.
Tim Downtown, Ca |
03-10-2023, 10:24 PM | #3 |
Re: Engine Srand
Generally Never use the block bellhousing area on a V8, 32-48 block. Newc
03-14-2023, 04:13 PM | #4 |
Re: Engine Srand
Agreed.... it can brake and engine will fall down on the floor ...may causing even more damadge
03-15-2023, 08:53 PM | #5 |
Re: Engine Srand
