Old 09-20-2018, 11:31 AM   #1
Snuff
Default No Emergency Brake
I have no emergency brake on my 1952 Ford F1.
The rear end was changed to what may be from a Mustang.
There is No emergency brake system from the rear drums forward.
If anyone can give me advise on what my options are for a working
emergency brake system that would be appreciated.
Snuff is offline   Reply With Quote
Old 09-20-2018, 11:45 AM   #2
GB SISSON
GB SISSON's Avatar
Default Re: No Emergency Brake
Wilwood makes a mechanical caliper along with a disc brake rotor to mount on the driveshaft. I adapted them to my skidsteer. Often used with rear axle swaps on hot rods and 4x4 vehicles.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 09-20-2018, 04:28 PM   #3
Snuff
Thank you for your reply.
Still not sure it is not the original rear end.
If original parts seam to be available.
Snuff
Old 09-20-2018, 04:31 PM   #4
Ggmac
If it's drum brake all that may be required are some cables run to your handle
Old 09-20-2018, 04:32 PM   #5
JSeery
JSeery's Avatar
Should be able to use the original rear axle emergency brake setup. The cables could be adapted to the original brake handle.
Old 09-20-2018, 06:31 PM   #6
40cpe
40cpe's Avatar
If you could post a picture(s) of your axle someone here could probably tell you if it is original. If it isn't I would wager that someone will tell you a range of years it was used.
Old 09-20-2018, 09:07 PM   #7
paul2748
paul2748's Avatar
If it is an 8 or 9 inch rear inch rear used used in the 60's and up Fords, most cables from 49 to 90's (and maybe later) should ft. I have a 54 Ford with a 9 inch rear (57) and the 54 cables "bolted" right up with no modification.
In my 48 Ford with an 8 inch rear, I am using the stock brake handle with the cables off the rear (68 Mercury Montego). I did have to make a bracket to hold the back end of the stock front cable which I bolted to the floor pan.
Look for cable off a Mustang, Fairlane or most any Ford product. They do come in different lengths so make sure what length you need. In my opinion, the ones that are one piece are the easiest to work with. You also need to make brackets to hold the end of the outer cable to the frame or floor pan
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-20-2018, 10:12 PM   #8
TomT/Williamsburg
TomT/Williamsburg's Avatar
Unless you want to stay stock, Lokar makes a nice setup that works with most old Ford park brake handles. I have a 9" in my present 32 project, with the Lokar cables but using the stock 32 pb handle ... I have also used their system on my old 40 coupe and will on my 40 pickup project that is next in line .....
TomT/Williamsburg is offline   Reply With Quote
Old 09-20-2018, 10:22 PM   #9
GB SISSON
GB SISSON's Avatar
Mustang is bound to be a small 5 bolt lug pattern. Certainly not 'truck-like'. The F1 would be 5 lug on 5 1/2" pattern. The mustang something like 5 on 4 1/2. Why someone would mount a small car axle under a pickup is beyond me.
Old 09-21-2018, 12:53 AM   #10
Tinker
Tinker's Avatar
It's great you are thinking or concerned about having a e brake. I commend you.
Old 09-21-2018, 06:51 AM   #11
Frank Miller
Frank Miller's Avatar
Here is a wild ass guess but there were some trucks that had the e brake mounted on the driveshaft. If the rearend is out of one of those or just the backing plates, you may be missing some components for the e brake. That is not a problem you just need to know what you have and my need a few small parts to hook up the cable. Drum brakes are pretty standard across the board regardless of make model and year.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 09-21-2018, 08:26 AM   #12
JSeery
JSeery's Avatar
How about posting some photos of the backing plates and the rear axle center section?
Old 09-21-2018, 10:36 AM   #13
Snuff
Thank you to all who responded to my post.
I feel getting the Cabel’s that match the backing plates
Fitting them to the original cable from the brake Handel
May be the answer to this situation.
Again thank you all
Snuff
Old 09-21-2018, 01:36 PM   #14
Snuff
40 cpe recemended pictures.
I hope these come through and help.
File Type: jpg A7DF7AA3-5030-462D-A3E8-C3E82E623571.jpg (22.8 KB, 21 views)
Old 09-21-2018, 02:42 PM   #15
alanwoodieman
fair picture of the center section, how about a picture of the backing plate.
Old 09-21-2018, 02:45 PM   #16
JSeery
JSeery's Avatar
Looks like a 9 inch to me. What is the lug nut pattern, 5 x 5 1/2 ?
