Old 01-16-2021, 08:17 PM   #1
1930artdeco
1930artdeco's Avatar
Default front plate dumb question
Hi All,
I am want to hang a tour plate on the front bar and have a dumb question. How do you do it? The plate has two holes where the bolt goes through but if I do that then I can't clamp it to the bar. Do the clamps just clamp to the plate or does the bolt go through the plate?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-16-2021, 08:41 PM   #2
midgetracer
midgetracer's Avatar
Default Re: front plate dumb question
Bolt goes through the plate.
midgetracer is offline   Reply With Quote
Old 01-17-2021, 10:33 AM   #3
w.michael
w.michael's Avatar
I have an old pair of clamps that are shaped in a way that the bolt can not go through the plate. The plate hangs below the bar, and the ridge around the edge of the plate clamps between the two halves of the clamp. The two halves are not identical. It's not a good system, and tends to break out a chunk on the edge of the plate. If that is what you have, look for another set of clamps.
Even if I could find my old set of clamps, I'm not smart enough to post pictures.
W. Michael
w.michael is offline   Reply With Quote
Old 01-17-2021, 11:18 AM   #4
Bob C
Is this what you are asking about?
Bob C is online now   Reply With Quote
Old 01-17-2021, 11:36 AM   #5
1930artdeco
That’s it. I figured it out. Knew it was a brain fart.
Mike
1957 Country Sedan
Old 01-17-2021, 02:27 PM   #6
McMimmcs
McMimmcs's Avatar
Mike
Not something we all haven’t experienced. Don’t let it bother you. At least you have the answer.
Old 01-17-2021, 04:24 PM   #7
Synchro909
Synchro909's Avatar
In this jurisdiction, we are exempt from running a front plate on these cars but if we had to, I think I'd just zip tie it to the front bumper or at the most, make a mount for that location. I don't like the idea of putting it on the headlight bar.
Old 01-17-2021, 07:09 PM   #8
Tacoma Bob
Tacoma Bob's Avatar
Here is my solution. This was made for my Model "A" street rod years ago.
Tacoma Bob is offline   Reply With Quote
Old 01-17-2021, 07:33 PM   #9
TMarsh
Just went out in the garage and put mine on like BobCs picture shows, never could figure that out before, many thanks
TMarsh is offline   Reply With Quote
