Old 09-24-2021, 08:31 PM   #1
jdpalmer
jdpalmer's Avatar
Angry oil around spark plug
Small amount of oil around spark plug could this be rings or head gasket? around no 3 only
Jimmy Palmer
jdpalmer is offline   Reply With Quote
Old 09-24-2021, 10:22 PM   #2
lrf
Default Re: oil around spark plug
You need to tighten the spark plug a LITTLE bit more or better yet, get a new plug washer. Install the washer with the split side down. It's not rings or head gasket.
lrf is offline   Reply With Quote
Old 09-25-2021, 08:19 AM   #3
Big hammer
Spark plug washers do wear out!
get a bigger hammer tap done
Old 09-26-2021, 08:01 PM   #4
Jeff/Illinois
Jeff/Illinois's Avatar
jd, I had the same thing on a Flathead Ford V-8, thought 'What the ----???"
It was the spark plug gasket! Never had that happen before in 50 years of fooling with antique Fords
