07-14-2020, 10:43 AM | #1 |
Carburetor base gasket
The base gasket on my Tillotson carburetor is leaking, can I skip the gasket and use permatex liquid gasket or just cut a new one out from sheet gasket?
07-14-2020, 10:49 AM | #2 |
Re: Carburetor base gasket
Not an expert on Tillotson but they tend to warp so make sure the surfaces are flat. I would not recommend using a liquid gasket. Gaskets are available or cut your own. Don't over tighten the screws.
Ruth "Sometimes you really DO need to read the whole thread" |
07-14-2020, 10:54 AM | #3 |
Make or buy a gasket !
07-14-2020, 10:59 AM | #4 |
I checked it and it is straight, I don't think I over torqued them, maybe not tight enough. I will make one tonight from 1/32 material and re-torque them after running a while.
Thanks |
07-14-2020, 11:54 AM | #5 |
