Old 07-12-2020, 02:56 PM   #1
Reelnative
Reelnative's Avatar
Default Engine noise?
I acquired a new noise over the past weekend, I thought it was a belt noise so I adjusted/ replaced the belt. Did not go away!!! I removed the belt and noise didn’t go away, stethoscoped the water pump, alt (6volt positive ground) with belt on, distributor with belt off, touched every nut and bolt I can think off but noise is still there. This is my daily driver and don’t want to damage anything else. What’s my next step?
Reelnative is offline   Reply With Quote
Old 07-12-2020, 03:23 PM   #2
WHN
Default Re: Engine noise?
What kind of noise?
How long have you had the car and how many miles have you driven it.
Model A’s car make all kinds of noises. Some just go away.
If it sounds like it’s in the top of engine, could be valve sticking. Marvel Oil in gas will help that.
I would not recommend rushing into taking things apart.
A dry distributor can also start making noises.
More info needed.
Enjoy.
WHN is offline   Reply With Quote
Old 07-12-2020, 03:50 PM   #3
Patrick L.
Patrick L.'s Avatar
Like WHN mentioned, what kind of of noise, what does it sound like. And were is it coming from ? A cheap auto store stethoscope, dowel, hose, can help locate it.
Old 07-12-2020, 03:59 PM   #4
Dean Lemoine
Dean Lemoine's Avatar
If it’s a squealing noise, kind of sounds like a fan belt? You might want to make sure the distributor is well oiled. How do I know this, you ask?
Dean Lemoine is offline   Reply With Quote
Old 07-12-2020, 06:18 PM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Make sure your crank pulley is not loose or cracked.
Jacksonlll is offline   Reply With Quote
Old 07-12-2020, 06:49 PM   #6
jg61hawk
you are vague on the description... I had the starter rod just rubbing on the firewall and the noise was incredible for such a small contact...but the metal to metal was just right to sound much worse than it was. Check all pass through..... starter, gas, etc...........
jg61hawk is offline   Reply With Quote
Old 07-12-2020, 07:54 PM   #7
aermotor
The starter rod is negative and the firewall is positive so if they are rubbing you are probably hearing electrical arcing.
John
aermotor is offline   Reply With Quote
Old 07-12-2020, 10:34 PM   #8
Jack Shaft
I'm polarized by the above statement.
Jack Shaft is offline   Reply With Quote
Old 07-12-2020, 11:21 PM   #9
Ruth
Shocking!
John
I certainly hope your starter rod is insulated from the positive side.
Ruth
Old 07-13-2020, 05:45 AM   #10
Patrick L.
Patrick L.'s Avatar
Shocking!
LOL !
Old 07-13-2020, 06:59 AM   #11
aermotor
I guess I stated wrong in post #7. Please explain when and how the sparks fly when the starter rod touches the firewall when the insulation in the rod retainer around the rod is missing. I don't understand - the plus battery cable is connected to the frame (firewall) so how does the negative post enter into the picture to cause the sparks?
John
Old 07-13-2020, 07:13 AM   #12
Jack Shaft
Your starter switch is bad.
Old 07-13-2020, 07:44 AM   #13
aermotor
How is it bad? It works and starts the car, the rod sparks when it touches the firewall because of no insulation in the rod centering retainer. I am just trying to understand the currant flow to cause this. Is it only when the switch is made or any time the rod touches the firewall?
John
Old 07-13-2020, 08:44 AM   #14
Patrick L.
Patrick L.'s Avatar
John
There should be no electrons at all in the starter rod. Its insulated from the switch.
Old 07-13-2020, 11:11 AM   #15
Ruth
This "kit" insulates the plunger (starter rod) from the switch. The little cross goes in the end of the plunger (starter rod). If you are getting sparks you better check out your switch.
https://www.snydersantiqueauto.com/P...earchByKeyword
Maybe think about getting a housing insulator while you are at it. https://www.snydersantiqueauto.com/P...-INSULATOR-KIT
Ruth
Old 07-13-2020, 11:25 AM   #16
Jack Shaft
It's not bad,just not right
Old 07-13-2020, 03:53 PM   #17
Reelnative
Reelnative's Avatar
Found my noise! Carb to intake manifold gasket.
Old 07-13-2020, 04:32 PM   #18
Patrick L.
Patrick L.'s Avatar
Good. Easy fix.
Old 07-13-2020, 04:33 PM   #19
john in illinois
john in illinois's Avatar
Good for you. It’s always something.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-13-2020, 06:06 PM   #20
Big hammer
Good! It's funny how noise will travel, like leaks!
get a bigger hammer tap done
