Old 03-12-2024, 09:12 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 1933 Amber cowl lamp lens
Does anyone make amber cowl lamp lenses? If not, has anyone painted the clear lenses amber? Thanks!
Tim Carlig
dean333 is offline   Reply With Quote
Old 03-12-2024, 09:19 PM   #2
DavidG
DavidG's Avatar
Default Re: 1933 Amber cowl lamp lens
I don't recall anyone making an amber lens. There is translucent red paint for tail lamps and perhaps a comparable amber/yellow paint exists for your purpose.
Old 03-12-2024, 09:51 PM   #3
dean333
dean333's Avatar
How about this one?
Tim Carlig
Old 03-12-2024, 11:51 PM   #4
Newc
Newc's Avatar
Glass paint of many colors in large hobby/craft stores. We use it to create amber 6 volt turning bulbs/ lights. Newc
Old 03-13-2024, 01:34 AM   #5
deuce lover
deuce lover's Avatar
How about using a amber bulb?
Here is a bulb I used years ago in a '32 cowl light.I went to Pep Boys and they had the plastic socket and these bulbs. The plastic socket fit snuggly in the orig bulb socket.The plastic sockt has to terminals and I soldered wires to them.One is the ground .It worked perfectly.On a 33-34 the orig bulb socket clips on the reflector.You will see that when you open up the cowl light.Now this was 12V
Old 03-13-2024, 03:28 AM   #6
dean333
dean333's Avatar
Amber 6V LEDs not available, I’m just going to paint the lens.
Tim Carlig
Old 03-13-2024, 04:50 AM   #7
deuce lover
I believe you can paint the bulb as there was special paint at one time.
6V amber LED here on Ebay but dual contact.
https://www.ebay.com/itm/153457030390
Old 03-13-2024, 06:45 AM   #8
dean333
dean333's Avatar
I think translucent stained glass paint is the ticket.
Tim Carlig
Old 03-13-2024, 07:16 AM   #9
rockfla
rockfla's Avatar
IF you SO desire, you can send me one of your original lenses, I have a good friend here in town that can take a mold of your lens and recast you some in any color plastic you want. He can do amazing work. This is a Cadillac horn button he duplicated, from what I understand they are like hens teeth. Quite a long process to do and not that yours will be that difficult BUT wanted you to see what he can do!!!!
Old 03-13-2024, 08:06 AM   #10
dean333
dean333's Avatar
Thanks Robert, a $9 can of paint will do the trick I believe.
Tim Carlig
Old 03-14-2024, 02:06 AM   #11
highbeams
highbeams's Avatar
No need for color. The original lamps are EXTREMELY BRIGHT! for directionals use; a jaw-dropper when one views them for the first time! Thank You -
(with your extremely bright-blinking cowl 'directional, and viewing the oncoming car, slowing, preparing to stop, stopping; monitor the situation - replies welcome!
highbeams is offline   Reply With Quote
