Old 05-18-2022, 10:50 PM   #1
Gary57210
Gary57210's Avatar
Default Rope on the back of front seat
On the 31 Slant window, are there any dimensions as to wear the grab rope is located?
Gary57210 is offline   Reply With Quote
Old 05-19-2022, 07:13 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Rope on the back of front seat
The metal back should have D-nuts for robe rail end screws. Not all had robe rails. Std did not and some had a flap.
Oldbluoval is offline   Reply With Quote
Old 05-19-2022, 09:54 AM   #3
Gary57210
Gary57210's Avatar
My seat is already upholstered but there was the rope included when I bought the car. I would like to know the location of the nuts if possible
Old 05-19-2022, 01:57 PM   #4
1931 flamingo
1931 flamingo's Avatar
Feel around with your fingers in the upper RH and LH corners, should be able to feel the D-nuts.
Paul in CT
Old 05-19-2022, 02:29 PM   #5
Bill Cilker
Bill Cilker's Avatar
Gary
Here are pictures from my SW sedan of the approximate location of the 2 nuts per side. I used a needle to find them. The SW sedans used a different end on the lap robe rope than the straight window sedans. The screw is 1-1/8" - 10-32 oval head screw with the end pointed.
good luck
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 05-19-2022, 09:05 PM   #6
Gary57210
Gary57210's Avatar
I am unable to open the pictures. I guess I don't have enough posts. I will come back to this when I have enough. Thank you for your help. Now after I posted this the pictures showed up.
Old 05-21-2022, 11:42 AM   #7
duke36
Approx 2 1/8" down from the seat top, and 31" o.c between end brackets. 1 pair each bracket screws are horiz. approx. 1" apart. Use an upholstery needle to probe as Mr.Cilker suggests.
duke36 is offline   Reply With Quote
