05-18-2022, 10:50 PM | #1 |
Rope on the back of front seat
On the 31 Slant window, are there any dimensions as to wear the grab rope is located?
05-19-2022, 07:13 AM | #2 |
Re: Rope on the back of front seat
The metal back should have D-nuts for robe rail end screws. Not all had robe rails. Std did not and some had a flap.
05-19-2022, 09:54 AM | #3 |
My seat is already upholstered but there was the rope included when I bought the car. I would like to know the location of the nuts if possible
05-19-2022, 01:57 PM | #4 |
Feel around with your fingers in the upper RH and LH corners, should be able to feel the D-nuts.
Paul in CT |
05-19-2022, 02:29 PM | #5 |
Gary
Here are pictures from my SW sedan of the approximate location of the 2 nuts per side. I used a needle to find them. The SW sedans used a different end on the lap robe rope than the straight window sedans. The screw is 1-1/8" - 10-32 oval head screw with the end pointed. good luck
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
05-19-2022, 09:05 PM | #6 |
05-21-2022, 11:42 AM | #7 |
Approx 2 1/8" down from the seat top, and 31" o.c between end brackets. 1 pair each bracket screws are horiz. approx. 1" apart. Use an upholstery needle to probe as Mr.Cilker suggests.
