Old 04-25-2020, 08:25 AM   #1
Rex Smith
Rex Smith's Avatar
Default Door Lock Issue
I can’t open the drivers door of my ‘30 coupe from the outside. The slide lock seems to be engaged, even though it’s slid all the way to the unlocked position. If I remove the two screws from the slide lock, allowing me to move it even further in the unlocked direction, I am then able to turn the handle. This tells me that I probably need to grind some metal off the lock (or off of something). However, it’s not clear what to grind, since I can’t see inside the door to see where the conflict is. I assume someone on this list is familiar enough with this to tell me what to grind (or bend?)
Rex Smith is offline   Reply With Quote
Old 04-25-2020, 08:43 AM   #2
rocket1
Default Re: Door Lock Issue
brattons sells new door latches with the locking mech.$34.00
rocket1 is offline   Reply With Quote
Old 04-25-2020, 10:40 AM   #3
Gary WA
Gary WA's Avatar
I assume you have the panel removed? I have no coupe but others! same locking mech. so why cant you see it!? Use a mirror and flashlight if behind something.?? How long has it been like this or just happen? Red circle one may have gone up over bracket?
www.whidbeymodelaclub.com
Old 04-25-2020, 01:07 PM   #4
Rex Smith
Rex Smith's Avatar
Thanks Gary, a little more investigation is required on my part. I see you're at Whidbey Island. Brings back memories. I was in a Navy patrol squadron at NAS Whidbey in the '60s.
Old 04-25-2020, 01:57 PM   #5
Rex Smith
Rex Smith's Avatar
Got it. I took the mechanism out and bent the lock tang just a little. Works fine now.
Old 04-25-2020, 02:03 PM   #6
Gary WA
Gary WA's Avatar
Great!
