04-24-2020, 05:31 AM | #21 | |
Re: Is there a way to reset the ammeter to zero?
Thanks for the link. It is interesting reading. Sent from my iPhone using Tapatalk |
04-24-2020, 07:35 AM | #22 |
Mikek #5, is 100% correct.
I have gone through and done the same. |
04-24-2020, 12:02 PM | #23 | |
Ammeters are simple devices, isolate the issue. |
04-24-2020, 05:29 PM | #24 | |
I’ve had the battery disconnected in the past, and the ammeter still read -2. The power cutoff appears to be working as designed. I’m guessing that at some point the gauge pegged itself on 20+ and bent the needle. After a start, I see the gauge hover around 10 or so for a bit while charging; so, the gauge itself does seem to work. Sent from my iPhone using Tapatalk |
04-24-2020, 09:37 PM | #25 |
Could be me, or maybe an optical illusion - seems the label/indicator/scale is not referenced. Perhaps the movement assembly is not referenced correctly to the label/scale correctly?
Just a observation/guess from someone who has never seen the insides of an A ammeter. |
04-25-2020, 12:20 AM | #26 |
