Old 04-22-2020, 03:54 PM   #1
shew01
shew01's Avatar
Default Is there a way to reset the ammeter to zero?
I just had the instrument panel cover off to install a dash light, and I didn’t think of this question until I had everything buttoned back up. (Sorry, I should have thought of this while it was apart, but I was hesitant to rummage around too much for fear of introducing a short into one of the wires behind the panel. From what I have read, that area of the car can be finicky.)
The previous owner installed a power cutoff in the car. When the power is turned “off” in the car, the ammeter tends to “center” itself on -2, rather than 0. Is there a set screw on the back of the ammeter that can reset it to 0? If not, is there some other way to reset the ammeter to 0?
shew01 is offline   Reply With Quote
Old 04-22-2020, 04:05 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Is there a way to reset the ammeter to zero?
No, there no screw to adjust it. Consider where it sits now (around -2) to be zero and mentally go from there.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 04-22-2020, 04:24 PM   #3
johnbuckley
johnbuckley's Avatar
parralax may make the dirver see a different charge than the passenger!
johnbuckley is offline   Reply With Quote
Old 04-22-2020, 04:33 PM   #4
Ernie Vitucci
Perhaps just put a dot of paint on the glass is that location so that you can always tell where the actual neutral position is. Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 04-22-2020, 04:48 PM   #5
MikeK
MikeK's Avatar
If you disassemble the ammeter you can bend the needle that much. The needle is rather thin aluminum, much like a throw away pie tin. It takes two pair of tweezers and a very light touch. You also need to watch how close it is to the face when you put it back together.
Not being a D'Arsonval meter movement, it is influenced by surrounding magnetic fields and the magnetic permeability of the car/panel/gas tank itself. The earth's magnetic field will also cause it to read slightly differently if the car is facing N-S vs. E-W. That said, you need to correct the needle the amount shown as 'off' before removal from the dash. If you set it to zero on the bench it may not show that when back in place!
MikeK is offline   Reply With Quote
Old 04-22-2020, 04:50 PM   #6
Big hammer
The next time you have the dash out you can take the amp meter apart, tweak the needle back to zero. My glass in the amp meter became loose so I took it apart, in the process I tweaked the needle off of zero and then put it back. Don't drink a lot of coffee before working on the meter, shaky hands!
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 04-22-2020, 05:30 PM   #7
Sunnybrook Farm
Sunnybrook Farm's Avatar
I had one yesterday that was not on zero when I held it in my hand, it must have become bent sometime, not sure where I got it from but I took it apart and barely touched the needle which is thinner than aluminum foil and it moved over to zero. You could get another one sometime and keep the current one as a spare if you don't want to mess with it since it is your only one.
Sunnybrook Farm is offline   Reply With Quote
Old 04-22-2020, 05:41 PM   #8
shew01
shew01's Avatar
Yes, parallax does seem to be at play. When I sit in the passenger seat, the meter looks closer to zero.
Old 04-22-2020, 05:44 PM   #9
shew01
shew01's Avatar
That’s not a bad idea. It would be nice to be at 0, but at least it appears to work. I hate to risk “fixing” it and end up breaking it.
Old 04-22-2020, 05:44 PM   #10
shew01
shew01's Avatar
Wow. I didn’t realize the ammeter could be so variable.
Old 04-22-2020, 05:45 PM   #11
shew01
shew01's Avatar
Good point.
Old 04-22-2020, 10:45 PM   #12
Bill G
Bill G's Avatar
Unless you are REALLY patient and can deal with little stuff that is somewhat delicate, I would not recommend you take the ammeter apart. You risk making the problem even worse, and the repop ammeters everyone sells don't fit in the instrument panel very well. I would leave well enough alone.
Bill G is offline   Reply With Quote
Old 04-23-2020, 04:47 AM   #13
larrys40
Make sure the needle pivot is free. With the needle out you might try slightly rotating the magnet ring inside the case. If it’s not an original one I wouldn’t even mess with it. Search for a decent original in Ebay or call Steve at Bert’s. There are many original ammeters out there. 25- 55 for a decent one is fair.
larrys40 is offline   Reply With Quote
Old 04-23-2020, 05:08 AM   #14
shew01
shew01's Avatar
I’m beginning to think this is wisdom. If it’s not truly broken, maybe I should not try to “fix” it.
Old 04-23-2020, 05:10 AM   #15
shew01
shew01's Avatar
That’s a thought. Thanks!
Old 04-23-2020, 11:17 AM   #16
rocket1
If you do not want to touch the needle rotate the face to zero,it won't be 100% accurate but now it won't annoy you.
rocket1 is offline   Reply With Quote
Old 04-23-2020, 07:19 PM   #17
Jeff/Illinois
Jeff/Illinois's Avatar
One day someone will pony up and make a GOOD Model A ammeter, and I think people won't have any trouble paying 75 bucks for an exact duplicate, a quality ammeter.
The ones coming in from overseas are pretty bad. The better Model A suppliers will tell you that.
Jeff/Illinois is offline   Reply With Quote
Old 04-23-2020, 09:50 PM   #18
Hitman
Lots of bandaid solutions so far. First, have you confirmed the position if the needle with no wires connected?
Hitman is offline   Reply With Quote
Old 04-23-2020, 10:06 PM   #19
Mike Peters
Mike Peters's Avatar
https://www.fordbarn.com/forum/showthread.php?t=20392
This is an old discussion about ammeters
Mike Peters is offline   Reply With Quote
Old 04-24-2020, 05:15 AM   #20
shew01
shew01's Avatar
Yes, the ammeter reads -2 then the main (aftermarket) power cutoff is turned off.
