Old 04-26-2020, 12:20 AM   #21
40 Deluxe
Default Re: Does anyone know this generator?
Originally Posted by BRENT in 10-uh-C View Post
Andy, -actually, that is NOT a generator, ...but was originally a GM Delco Alternator that has likely been converted to 6 volts by changing the internal voltage regulator. You can either replace the regulator, ...or you can convert it back to the correct style generator.
Long-forgotten fact: What you guys are calling an "alternator" was in fact officially termed a "Delcotron generator"! This is the wording used in Chevrolet ads in 1963 and some time thereafter. So the OP is correct in using the term "generator"!
Old 04-26-2020, 11:05 AM   #22
Purdy Swoft
Purdy Swoft's Avatar
Generators and alternators both generate amps if they are working properly or turning fast enough .
