03-17-2015, 11:03 AM | #1 |
Torque wheels
What is the recommended ft./lbs to torque the wheels of 31 A?
03-17-2015, 11:17 AM | #2 |
Re: Torque wheels
55 Ft Lbs, the crank will do this easily! Chief said, "Tighten them until they go, SCREEEECH"
Bill W.
03-17-2015, 11:25 AM | #3 |
Re: Torque wheels
Using the hand crank/ lug wrench, pull up with your legs.
03-17-2015, 11:27 AM | #4 |
Re: Torque wheels
Thank you Bill.
03-17-2015, 01:59 PM | #5 |
Re: Torque wheels
Torque them with dry threads.
03-17-2015, 03:40 PM | #6 |
Re: Torque wheels
03-17-2015, 03:57 PM | #7 |
Re: Torque wheels
I don't think so. They survived back then with a lug wrench and no AAA! Of course they did have original lug nuts.
http://www.abarnyard.com/ |
03-17-2015, 04:20 PM | #8 |
Re: Torque wheels
If you must find a spec...find a shop manual from a '60's-eary '70's big Ford or 1/2 ton pickup. Ford used the same lugnut (minus the acorn dome, dropped when Fords got hubcaps over the lugs in '32) well into modern torque-wrenching times. I would get an actual Ford spec and not assume things like the modern "shop manuals" for Model A's got anything right.
The one rule of thumb with unmeasured tightening is to NEVER use your biggest breaker bar. Not only will it be too tight, you'll need to find someone with a BIGGER wrench to get the thing off! |
03-17-2015, 04:28 PM | #9 | |
Re: Torque wheels
I was taught and have changed tires from when I was around 10 or so and I have never been a muscular sports person. The key is you are using your legs to do the force. Your legs are used to lifting your weight of a more than 50 lb body. So the less then 1 foot long crank handle will give you something around 50 lbs or probably more of torque. It is really quite scientific. It is such that a not so athletic women could change a tire if she knows the right way to do it. You are also likely to be very consistant with the torque. One day after high school a group of football players had a flat. BTW, I was the nerd they picked on at the time. So I watched from my bicycle as they could not get the lugs loose. After a bit, I went over and got them all loose. They were on pretty tight, but pulling up with my legs was all that I needed to break them all free. Wrenching is about feel. With some of the modern cars you need and get used to modern tools. When working on the A it is a mix of old world feel and modern used of accurate tools. Keep in mind that the length of the wrench is to give the proper torque for the size fastener for normal strength person. That is the torque values for the A fasteners. |
03-17-2015, 05:54 PM | #10 |
Re: Torque wheels
I use 50 lb/ft and don't use a torque wrench, just a calibrated elbow.
I don't put them on dry. |
03-17-2015, 06:01 PM | #11 |
Re: Torque wheels
I agree with Bill W and Patrick on the 50 to 55 torque. They will not loosen up. If you use a big 4 way like we used to on 50's cars, you can easily strip the threads on the lug bolts. Don't ask me how I know.
03-18-2015, 03:03 PM | #12 |
Re: Torque wheels
I agree with 55 #. I have driven a lot of miles and never found a loose lug nut.
A lot of sources say 65# but I think that is hard on the wheels. John |
03-18-2015, 03:39 PM | #13 |
Re: Torque wheels
I keep a torque wrench in every one of my vehicles with the appropriate socket and extension. Cheap insurance. years ago I bought a HF torque wrench for 9.95 with a coupon. Looked good and well made, it was my idea to keep it in my F150. I have Snap-on and Craftsman ones also. One of my friends started ribbing me about the cheap HF wrench and said I wouldn't use one of them to torque rods/ mains/heads etc on one of my racing engines I said why not if it is accurate. Had a friend that worked at a local community college that taught a calibration program, so I gave it to him with my SO and Craftsman to check them out. Turns out it was within 1 % of actual torque dialed in, actually better than the SO and Craftsman. Since then I believe it was Car Craft Mag did a test on them and a few others and came out with the same results. So that led me to buy 8 others for my other on the road vehicles(including my '29 Coupe and '29 PU), with the long handle they give excellent leverage.. Now I know some people feel that the only tools worth anything are SO and I agree they are fine and expensive tools, but in this instance the HF works well.. Your mileage may vary...
03-18-2015, 06:40 PM | #14 |
Re: Torque wheels
The Les Andrew's book says to torque the lugs to 64 ft. lbs. I have been using 64 lbs. for 12 years without any issues.
03-18-2015, 07:06 PM | #15 |
Re: Torque wheels
I torque anything that has a torque spec. I'm like holdover, I carry a cheap HF torque wrench in the car in case I need to torque my wheels back on. A lot of people laugh at me for it, but my stuff is always right. I guess it's a carry over from working on nuclear subs in the Navy.
kris |
03-18-2015, 07:48 PM | #16 |
Re: Torque wheels
03-18-2015, 09:55 PM | #17 | |
Re: Torque wheels
Don't get me wrong. I believe CONSERVATIVE figures (so called specs) have their place and prove useful. More damage is caused by over tightening (to large a tool for the job) than ever was done by under tightening.
03-19-2015, 12:06 AM | #18 |
Re: Torque wheels
I always grease the threads and taper and use the hand crank to tighten the lug nuts. When my elbow clicks it's tight enough.
I've seen people freak out when I mention greasing the threads and taper, but I've done it all my life, and never had a lug nut come loose until I wanted to remove it. I've seen a lot of people fight rusted threads and snap wheel studs due to rust. |
03-19-2015, 03:37 AM | #19 | |
Re: Torque wheels
I wasn't around in the 1920's, but I've read that torque wrenches were fairly new back then. I assume thats why Ford didn't have torque specs for anything. However, there are now torque specs for wheel nuts, head nuts, oil pan bolts, etc, etc. So far, I haven't been let down by the torque chart hanging on my wall that I got from Fastenal 15 years ago.
Most torque charts are pretty close to each other. Several examples for a 1/2" fine Grade 5 bolt: 65 ft-lbs lubed http://www.americanboltcorp.com/tech/techtorque.pdf 64 ft-lbs lubed http://www.repairengineering.com/bolt-torque-chart.html 64 ft-lbs lubed https://www.boltdepot.com/fastener-i...ed-Torque.aspx 1020 in-lbs -25-30% lubed = 63.75-59.5 ft-lbs http://www.federalscrewproducts.com/torque-chart.htm 63.7 ft-lb lubed https://www.fastenal.com/web/en/83/torque-calculator I suppose if you looked hard enough, you could find a torque chart someplace that was way different than the 5 I quickly found. I guess my point is that charts from reputable bolt suppliers are pretty close. If you want to tighten up fasteners to where you think it needs to be without a torque wrench, I'll still sleep at night. If you want to roll your eyes because I like using a torque wrench, I'll still be your friend. Quote:
kris |
03-19-2015, 06:26 AM | #20 |
Re: Torque wheels
A few years ago I worked on a 29 pickup that the owner had torqued the lug nuts on.He had gotten the specs from somebody on the old Fordbarn.He had tightened the nuts to 110 foot pounds.I said you must mean the axle nut,he said no,the lugs.I looked it up and sure enough I found the post advising him on the lug torque.I found out when I went to take the wheels off his truck.I twisted the first lug nut off with very little effort.Most were still tight,but they all had Mae-Wested.Almost all of them broke when I tried to remove them.Now we had to replace all the studs,and if we had to do that,we might as well go to cast drums.Other than that the brakes were in excellent shape.Rotating his tires that day turned into a $1000.job.
